Curtis software is menu driven. Meaning you just plug in, turn key on, and hit "connect".
select read "parameters"
Check vehicle mode setting under the "speed mode express" section.
What ever that is (type 0-1-2), go to that section.
(Assuming type 2- Torque mode) Go to type 2 torque mode section.
Read: (under Speed Limiter) —"Max Speed"
It will be a value between 0 and XXXX Rpms.
Set it to the maximum allowed. "Hit save"
Hit "disconnect"
Turn off key, unplug .
Done.
There are a TON of things that can be changed in there. Most of them will be a mistake to change.
Frodus at :
http://www.emf-power.com/ rents the programmers. Ask about the correct plug.
For any questions, email me.
Mizlplix@gmail.com Subject "Weego Whip".
