A1=positive., jump A2 to S1 ,S2=negative
If you jump A2 to S2 then then S1 will be your batt.negative and the motor turns backwards.A1 and 2 is the brushes S1 and 2 the ends of the field winding. Try to make sure the final hookup will turn the motor in its intended direction. Barna
