Re: how would this work out...
Ok so lets say you want 72 volts.
72 / 1.2 (AA voltage) = 60 cells in series to get 72 volts.
Lets say your bike uses 200 Wh/mile.
50 miles * 200 Wh/mile = 10,000 Wh.
10,000 Wh / 72 Volts = 139 Ah needed.
139 Ah / .7 Ah = 200 cells in parallel to get 139 Ah.
200 strings of 60 cells or 12000 AA cells.
This a very rough estimate, not sure how efficient a bike is, I know they aren't very aerodynamic, but they are lighter. And the conversion from Wh to Ah is also just an estimate. As you discharge the batteries the voltage drops, so you need more current to get the same Wh out.
So make it 220 strings in parallel to account for that, so that would mean 13200 cells.
