Old 10-05-2009, 04:05 PM
ZX-E's Avatar
ZX-E ZX-E is offline
ZX-E is on a distinguished road
Default ZX-E the Bike
My roommate (Alex, a4111) and me have been planning a conversion since January. I want to start a thread on our Kawasaki ZX-9R conversion. The bike is sitting in our garage right now with a warp 8 [now dual k91-4003s] inside the down-tubes. I also have 200 headway p cells sitting in my room. We're looking at a 156 [now 96 volt] volt setup using a synkromotive controller.
Check out the thread for the speed calculator I originally made to find the ideal gear ratio for the ninja project and a Rav4 at evcomponents:
http://www.diyelectriccar.com/forums...tor-36920.html
I'll post any questions we have about the project here if you guys don't mind .
-Rich
Old 10-05-2009, 08:37 PM
Big-Foot's Avatar
Big-Foot Big-Foot is offline
Big-Foot is on a distinguished road
Default Re: ZX-E the Bike
Just got my 93 ZX6E Donor yesterday....
Mine will be a 72v DC-Series system with AGM batteries (Optima Yellow).
I hope you have access to someone who can weld aluminum.
Regards - Randy
GT40 Replica in progress http://www.GT-Forty.com
Old 10-05-2009, 09:21 PM
ZX-E's Avatar
Sweet! How much did you get it for?
I do know a guy who does aluminum welding; albeit 5/8 thick aluminum, so it's going to be tricky. We're planning on using the motor mount design and build process as our senior Mechanical Engineering project.
-Rich
Old 10-06-2009, 09:04 AM
frodus's Avatar
frodus frodus is offline
frodus is on a distinguished road
note: 38120P cells are the 8Ah Headway cells, for people that didn't know.
Can't wait to see it Rich, its going to be a fun project.
Travis Gintz
www.evfr.net
Old 10-09-2009, 02:49 AM
Qer's Avatar
Qer Qer is offline
Send a message via ICQ to Qer Send a message via MSN to Qer
When I googled on 38120P I got 10Ah, 10C nominal and 20C max. Pretty ok I guess, but 200 Amps sounds low. On the other hand, maybe 200 Amps isn't low for an MC...
Soliton-Motors: 7-0
Old 10-09-2009, 05:01 AM
Big-Foot's Avatar
Bearing - Understood now with the Jackshaft.. My motor will protrude "some" on the right side without a jackshaft - but some to think of it, it would be easier to change ratios with a a jack... Hmmm..
Batteries - Interesting racks. How will you attach the metal straps to the cells?
Regards - Randy
Old 10-06-2009, 05:01 PM
Big-Foot's Avatar
I've got a few hundred in it. The bike's never been down and has less than 20k on it. New tires and brakes - plastic is all in pretty good shape.
5/8" thick aluminum - wow... That would take quite a welder to do that...
My Miller TIG will only go up to 200 amps and that's about 1/4" thick Aluminum that I could weld.
I'm going to be looking into other battery technology than the AGM. I would really like to get to the point where I could go 50-60 miles at 60 MPH.
Regards - Randy
Old 10-06-2009, 05:49 PM
ZX-E's Avatar
We're putting bearings inside the aluminum. It's going to be pretty complicated. But what I'm really not sure how to do is mount the batteries to the frame. If there's a will there's a way right?
At 60 mph with 196 8 amp hour cells I'm looking at about a fifty mile range . They aren't the most energy dense cells, but four of them in parallel can do 500 amps (battery side) easily at about 15 C which is all I need for peak power motor side.
Here's the electrical portion of a calculator I made in excel that I used to come up with those numbers:
-Rich
Old 10-06-2009, 06:55 PM
Big-Foot's Avatar
You lost me on that one...
Build a carriage out of angle aluminum or steel. If steel - just bolt it up to your frame.. The fuel tanks are larger than you might expect if the bottom is cut out...
500 amps is a BUNCH...
Regards - Randy
Old 10-10-2009, 02:27 AM
ZX-E's Avatar
Chinoz 156V 7 amp charger instructions. These are pretty new at EVComponents. I think some people have had questions about them.
-Rich
