Old 11-18-2007, 01:09 PM
Xanerrix Xanerrix is offline
Xanerrix is on a distinguished road
Default transmission losses
Hello,
I was wondering where I could get reliable info on losses in transmission and roling resistance coeficients.
Any information is helpful!
Thank you
Andre
Old 11-19-2007, 08:01 PM
david85's Avatar
david85 david85 is offline
david85 will become famous soon enough
Default Re: transmission losses
The best info I ever got was that there is a 30% loss from the crankshaft to the road, the 30% rule seems to be the norm for estimating crankshaft Hp with an engine still in a vehicle.
I also saw from one source that the average differential is 94% efficient, but I haven't been able to confirm this.
My bet is that the transmission is eating up at least 10%.
Old 11-20-2007, 06:45 AM
That was exactly what I meant, thank you.
BTW, is that for an automatic or a manual transmition?
Thanks for the help!
Andre
Old 11-20-2007, 11:18 AM
david85's Avatar
If the transmission has a locking torque converter, I doubt there will be that much difference. The ford C6 HD tranny for example (open TC) is what I call a "fuel eater", the lighter duty AOD (locking TC) is much better, but an auto tranny still has to build fluid pressure to activate and hold each gear, so there will still be a disadvantage compaired to a manual.
From experience, I haven't noticed much difference in MPGs between auto and stick, becuause auto can keep engine RPMs more consistent (torque converter makes this possible), but consistency doesn't matter very much with elecrtic motors, so I suspect the manual is still the better choice.
Something else to consider, is that an automatic cannot be put in gear unless the imput shaft is already spinning, because the hyraulics have to start pumping first, but there also isn't very much holding force actually applied to the internal clutch packs at idle, so there may also be a problem if you try to take advantage of all the low end torque that electric motors are usually blessed with. This would also imply having to "idle" your electric motor.
Old 11-20-2007, 11:45 AM
I see, I guess this would not be very desirable.
Thank you very much
Andre
