DIY Electric Car Forums > General Forum > Chit Chat
Notices
Old 11-06-2009, 10:12 PM
david85's Avatar
david85 david85 is offline
david85 will become famous soon enough
Default Re: Hello trying to discover the electric car world
Just found this one: http://www.evalbum.com/2898
To my knowlege, this is the worlds first conversion of an F250 (4x4 no less!!!). Just don't look at his build cost....
1978 with C6 and 7.5L V8.....gotta love that era. Smallest/lightest truck you could get in the F series and yet available with the biggest engine and toughest tranny. You could even buy crazy highway gears like 2:1 or lower than 4.10 if you wanted. These days, you buy what they sell you.
That truck might not be too bad to convert if you are comparing against a new ranger. 1970s F150s are fairly light. Not as light as 1980-1983 with the swiss cheese frames, but still pretty good. Frames are also strong enough to take the load.
Getting something that can do 70 MPH on $5000 might be a challenge though. The 1970s fords look great IMO, but they don't have much going for them at higher speed. Did Randy get back to you yet? I suspect motor and controller will already use up nearly all of your budget.
I knew what kind of vehicle I wanted to drive since before I was old enough to drive,
now I am building something close to it.. http://www.diyelectriccar.com/forums...ion-26587.html
Garage: http://www.diyelectriccar.com/garage/cars/206
Old 11-07-2009, 01:27 PM
lazydfarms lazydfarms is offline
lazydfarms is on a distinguished road
Thanks for the info once again. Ya I'm pretty much to the point where I've abandoned any idea of doing a full size truck...its just way too far out of my budget. I do like the style and versatility of the old trucks but came to a realization that the application of an electric commuter is just that; a commuter. Short distances, no payload so a full size truck isn't even suited to that in the first place (although people down home use them regularly to run around which is questionable with $3.50+ gasoline). I'm starting to consider my possibilities for car platforms or possibly a low option Ranger. Randy has not got back to me yet which is ok because I'm going to look at used options for the motor and controller. From what I read a forklift is likely best for heavy duty used parts so I'll investigate that further. Thanks for your input
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Powered by NuWiki v1.3 Beta 5 Copyright ©2006-2007, NuHit, LLC
Zoints SEO v2.3.0 by Zoints & Computer-Logic.org
Copyright 2009 Green Web Publishing, LLC
