Old 08-16-2007, 09:23 PM
Default Re: [EVDL] 10th S10 outing/13 OUTING 127MILES
[quote]David Dymaxion wrote:
> I had to go to an aluminum driveshaft to get rid of a similar vibration in my
> gasser . (which was Chevy's TSB fix, balancing made it worse).
I put 4.10 gears in a vehicle and the stock steel driveshaft which
previously had no vibration; had one with the increase in shaft rpm
going from 2.73 gears to 4.10's at highway speeds. A switch to a
lighter weight aluminum shaft made the vibration go away.
Are you running a Mark Williams driveshaft Dennis? What's it made of?
What's the maker of the shaft say about the vibration?
Is your Armature balanced extremely well? Up to what rpm?
For subscription options, see
http://lists.sjsu.edu/mailman/listinfo/ev
