DIY Electric Car Forums > General Forum > Chit Chat
Old 05-04-2012, 04:36 PM
E_vehicle_crazy E_vehicle_crazy is offline
E_vehicle_crazy is on a distinguished road
Default How can I determine the hp and torque needed to maintain my highway speed?
Hi I have a question about determining the hp or kw and toque I will need to run my 7000lbs project truck.
I have read lots of articles that give me some good information but I can’t seem to put all the pieces together properly and make it work out.
I can determine the rpm I need the drive shaft and motor to turn to maintain the highway speed with the gear ratios and tire size. I have gone through the hp Formulas and the Rolling Resistance. The problem I am having is determining the hp and torque needed to a speed of say 100kph and the extra hp and torque to bring it up to speed. I just can’t seem to put it all together properly.
If anyone can help or point me in the right direction it would be greatly appreciated.
Thanks for your time.
Old 05-04-2012, 05:34 PM
Ivansgarage's Avatar
Ivansgarage Ivansgarage is offline
Ivansgarage is on a distinguished road
Default Re: How can I determine the hp and torque needed to maintain my highway speed?
I went over to topeka electric motor last week and went for a ride in Kevins truck (full size pickup) this truck runns like it had a v8 in it..
Unbeleivable, runs perfect, cant say enought about this truck.
And best of all, this truck is proof you DON'T need 2000 amps and 300+ volts...
check out these links..
this is the motor and controller in the truck
http://electriccarinternational.com/...Engines-AC.php
Here is the link to the truck. Topeka Electric Motor
http://topekaelectricmotor.com/elect...les/ac-project
IvansGarage 1999 electric sonoma
http://ivanbennett.com/
Old 05-04-2012, 07:10 PM
mizlplix's Avatar
mizlplix mizlplix is offline
mizlplix will become famous soon enough
Come on, Ivan. Dont hold back. Tell us a little more...
ivanbennett dot com/forum
AC Vehicle Propulsion Study Group
Old 05-05-2012, 06:49 AM
Well Miz all i can say is i am working on a ac motor 3phase about 15hp
225lbs water cooled. Don't have the finall numbers yet on hp and torque
after the rewind.
Ivan
Old 05-06-2012, 11:00 AM
ruckus ruckus is offline
ruckus has a little shameless behaviour in the past
Hello,
This page is very helpful:
http://ecomodder.com/forum/tool-aero...resistance.php
You can add hills, headwind, and parasitic loads to get a "real" number. Rounding down will only result in a system that under-performs, so I recommend rounding up. You will have losses in the controller and motor and so should figure an addition 10-20%.
Cheers
