Originally Posted by Tesseract
Uh-huh... Surely a Chinese motor controller will be the very paragon of reliability and performance in comparison...
I would actually recommend one of the MADE-IN-USA water-cooled brushless motors... Except, there are none for sale.
If you want air-cooled BLDC you can call Powertec. With typical american service they won't bother to call you back or even send you a price sheet with big numbers on it.
Maybe this "Scott Drive" will be the exception that proves the rule, but as I pointed out, it's the same type of motor/controller as used in small computer fans - an application where low starting torque and high amplitude torque ripple (+/-15%) isn't an issue. In a traction drive, both of those downsides are objectionable, if not crippling.
Really? Then why has heavy industry shifted from brushed motors to BLDC? Again, Powertec and other BLDC documentation show very impressive starting torques so this argument seems a bit of a red herring.
Most electric motors don't have a torque problem, they have a hp problem. Especially inefficient air-cooled Brushed DC motors. Look at the specs, this motor weighs 54lbs LESS than the 11" yet is rated at 45+ hp continuous. Brushed motors just can't compete for long high-speed driving. How many OEMs use brushed motors? None. Hmmmm, wonder why?
I'd hold off on recommending this system until someone unbiased has actually tried it. On paper it doesn't look particularly impressive to me. $5500 for 80kW peak isn't any more powerful than the Curtis 1238 + AC-50, and it's actually more expensive than the latter system when purchased from a known good vendor like frodus here.
It is called the Scott Drive 100 because the motor is rated at 100kw peak, not 80. They don't list a max wattage for the controller but it calculates to 200kva. According to the listed torque figures, the AC-50/Curtis is not in the same league. The "100" is the "derated" model. More power and voltage should be coming soon.
The Scott Drive system is currently installed and being used in several cars in NZ. Several thousand km and no problems reported. The controller is not Chinese, but made with quality in New Zealand.
I look forward to meeting you (I think your controllers are brilliant) at EVCCON where I will likely have a Scott Drive for display along with the "brushed" '37 Jaguar.
Cheers
