DIY Electric Car Forums > EV Conversions and Builds > Electric Motors
Old 06-17-2012, 05:56 PM
onegreenev's Avatar
onegreenev onegreenev is offline
onegreenev is on a distinguished road
Default Re: GE aircraft generator
It looks like a dual post rather than 4. So it may be connected internally. Take a 12 volt battery and connect up to the two large terminals on the motor and see what it does? Can you take the cover off to have a look at the commutator and get some photos. This is nothing like I have. Mine is larger.
Go to youtube and look up gottdi and onegreenev. You will find my videos and you will see a few with the Starter Generator.
Change comes, one conversion at a time.
http://onegreenev.blogspot.com/
Old 06-22-2012, 12:06 PM
adeyo adeyo is online now
adeyo is an unknown quantity at this point
Default
Thanks. I'll try it. I'll check it those videos too. Maybe I'll use this for a go kart. With it being rated 28 volts on the outside plate, What would be a good Voltage to run it at as a go cart?
