Old 06-12-2012, 06:45 PM
coulombKid coulombKid is offline
NEAA Member
coulombKid is on a distinguished road
Default copper ceramic clutch disk
Has anyone used one of these in there conversion?
http://www.ebay.com/itm/150744626204...ht_3462wt_1396
I used to put them in my father's farm tractors. Each time they out lasted the tractor. It says it has a chromoly tempered hub. What are OEM hubs made from.
What this country needs is a good 10 dollar battery pack.
Old 06-12-2012, 06:59 PM
ricklearned's Avatar
ricklearned ricklearned is offline
ricklearned is on a distinguished road
Default Re: copper ceramic clutch disk
I used a simpler one from Scat without the springs. It was $35 and was copper + feramic. It used a heat treated hub with longer splines.
My 1973 VW Super Beetle Thread
http://www.diyelectriccar.com/forums...ild-74500.html
Old 06-19-2012, 02:05 PM
dougingraham's Avatar
dougingraham dougingraham is offline
dougingraham is on a distinguished road
I suspect it doesn't matter all that much what kind of clutch you use because we don't slip the clutch to start out and this is where most of the wear comes from.
I am guessing that in a typical conversion that isn't raced even a normal clutch will last forever.
I am more concerned with the fact that I have more than twice the ICE torque and I think maybe a heavier pressure plate would be a good idea.
Doug Ingraham
Rapid City, SD
1985 Mazda RX-7 GSL (1400+ EV miles)
Now on the road but still under construction.
Old 06-19-2012, 02:38 PM
aeroscott aeroscott is offline
aeroscott is on a distinguished road
they can take much more torque . not so good for slipping . great for evs!
Old 07-02-2012, 06:02 PM
NEAA Member
Various members have stripped out the splines of the clutch hub. Some of these were softened by welding. The after market clutch disk makers some times talk up the metallurgy of their hub.
