DIY foot throttle - DIY Electric Car Forums
Old 07-05-2012, 11:35 PM
PStechPaul's Avatar
PStechPaul PStechPaul is offline
PStechPaul will become famous soon enough
Lightbulb DIY foot throttle
I had an idea for a simple DIY foot throttle for an EV. Apparently the resistive potentiometer types are prone to wearing out and failure, and other types such as hall effect and LVDTs seem to be very expensive.
I don't know what specifications are needed, but for my own purposes using a standard 3 phase VFD controller, it will accept either a potentiometer or a variable voltage which can be set for 0-5 VDC. I have also used a computer joystick which is a 0-200k resistance, and I converted that to a +/- 5VDC signal which also provided reverse. But I think a foot operated throttle will be best.
I have some experience with LVDTs, but they are typically high precision and very expensive position sensors that require special circuitry. Here is a tutorial I found which helped refresh my memory:
http://www.macrosensors.com.cn/ms-lv...-tutorial.html
But the basic principle is very similar to a steel core moving within a magnetic solenoid. Here are some examples of AC and DC solenoids, and normally they are used to convert electrical power to mechanical power by pulling or pushing a plunger in a linear direction, usually about an inch or so.
However, the other property of a solenoid is that the inductance changes and is increased as the plunger is pulled in, and for an AC solenoid this is desireable because the current draw will decrease as the plunger pulls in. I happen to have a couple of solenoids and an LCR meter, so I ran a little test on one of them:
0.829" 53.6 mH 63.6 uSec
0.700" 62.5 mH 72.6 uSec
0.600" 76.0 mH
0.500" 89.7 mH
0.400" 111.8 mH
0.300" 137.2 mH 147.5 uSec
0.200" 166.9 mH
0.100" 228 mH
0.000" 288 mH 298.6 uSec
It would be very easy to design a circuit which could read and convert these inductance values to a range of voltage suitable for a throttle input. My idea would be to use a Microchip PIC with a 5VDC supply, and measure the inductance by applying a voltage and measuring the time for the current to reach a certain value. For a fixed voltage and a set current, the time is proportional to inductance, so for 5V and a current of 5mA, the times will be as shown in the third column above.
So it can read pedal position at least 3000 times per second, and it can utilize a look-up table to accomplish any linearization or custom response desired. For instance, it may be good to use a logarithmic or square law response, so that the first portion of travel provides very fine control, and the further it is pressed, the faster it responds.
The entire circuit, including the solenoid, could be built for, say, well under $5 in quantity, or maybe $20-$30 for a few prototypes. Maybe this is already available, so I might just build it for my own use, but if it would be a valuable product for the EV community, I can put more time and effort into it and make it available more quickly, like one month compared to 6 months. But I'm not familiar with the requirements and expectations, and maybe this has been done before.
Old 07-06-2012, 07:12 AM
Ivansgarage's Avatar
Ivansgarage Ivansgarage is offline
Ivansgarage is an unknown quantity at this point
Default Re: DIY foot throttle
I wonder how a big truck throttle would work out. These are just a 3 wire pot type ,Dont now what the ohms are.
They last forever.
http://www.ebay.com/itm/PETERBILT-38...-/300340779766
Ivan's Garage 1999 Electric Sonoma Pickup
http://ivanbennett.com
http://ivanbennett.com/forum
EV Hand wound motors.
Old 07-06-2012, 07:31 AM
Here is a pic of a peterbilt throttle
Old 07-06-2012, 09:52 AM
This is the wiring for that peterbilt throttle
Old 07-06-2012, 12:54 PM
azdeltawye's Avatar
azdeltawye azdeltawye is offline
azdeltawye is on a distinguished road
Originally Posted by PStechPaul View Post
I had an idea for a simple DIY foot throttle for an EV. Apparently the resistive potentiometer types are prone to wearing out and failure,....
Rube Goldberg would be very proud of your inductive throttle idea...
The Evnetics throttle uses a standard automotive grade TPS and is built very well. Check it out:
http://www.evnetics.com/evnetics-pro...ttle-assembly/
Darren Sims
Registered PE - Electrical
http://www.diyelectriccar.com/garage/cars/253
Old 07-06-2012, 03:34 PM
bjfreeman bjfreeman is offline
bjfreeman has a little shameless behaviour in the past
Send a message via Yahoo to bjfreeman
I model a throttle position sensor (TPS) in fly by wire mode. This way it does not matter what the actual sensor is, the output is standard. So you can have a Joystick or foot throttle.
I have found Throttle replacement at Auto stores for about $125.
http://www.autozone.com/autozone/acc...ensor/_/N-25dt
http://www.ebay.com/itm/E-Z-Go-ITS-I...-/110662703217
Men and their Toys.
http://roadwarrior.free-man.com/
Old 07-06-2012, 07:43 PM
piotrsko piotrsko is offline
piotrsko is on a distinguished road
Ok waaaayy back in the day: inductive "pots" like what the OP proposes were used as a resonant circuit, kinda like a very primitive PWM, EXCEPT they made average voltage / current instead of frequency. Less core involved, less inductance, more frequency, more effective voltage. Used mostly in "explosive" environs where you didn't want sparks. Also saw a modified one for a microphone.
FWIW: perhaps too much thinking and circuitry. YMMV.
Old 07-07-2012, 04:26 AM
one of the things not covered the TPS, is the monitoring of the TPS functionality.
Comercially there is testing for Opens, Shorts, Noise.
Newer ones now have dual sensing elements that are opposite, or in hall effects 90 degrees out of phase.
For some controllers, this is done, as the industry grows, I expect to see them separated.
Men and their Toys.
Old 07-07-2012, 02:16 PM
A thought, how about a 1inch by 1inch board that has standard output to Lin or CAN.
it would have analog input so it can interface to current sensors.
I have one I use in production, has more than is needed for a TPS, but I don't want to have a lot of hardware configurations. I rather do it in software.
but is someone wanted to make one for thier own using their own processor and code, then Kewl.
the discussion can be high level description for functionality.
Men and their Toys.
Tags
control, solenoid, speed, throttle
