Old 07-06-2012, 12:08 PM
Daox's Avatar
Daox Daox is offline
Daox is on a distinguished road
Default Mottcell 39Ah cell test results with PowerLab6
I don't post too much on this forum, but I've been working on rebuilding my Prius' PHEV kit (made by Enginer) since I had some issues with it, and I just wanted to share my findings.
The first step of this rebuild is evaluating every single cell in the PHEV kit's pack. The pack is made up of 32 "39Ah" Mottcell cells. The configuration is 16 in series, 2 in parallel. I've been using a Revolectrix PowerLab 6 charger to evaluate each cell. The process charges each cell up to 3.65V at 38A (~1C), then discharges it to 2.8V at 38A, and then recharges it. The Mottcell cells I've found with this cycling setup only give a max of 35Ah of capacity. This is from brand new unused cells. Some of my older (~2yr) used (and abused) cells are showing capacities of around 30Ah. This is quite disappointing to see that you don't even have the rated capacity. But, its what I have to work with and it'll have to do.
Here are the test results:
(highlighted cells are under 30Ah)
I'm a bit curious why some of the cells tested higher on the 2nd and 3rd tests. My strongest cell (#20) didn't see this effect when cycled multiple times.
The second step of the project is finishing up my BMS system I've been developing for a while now. I'll be sharing more info once I get everything in the car and working. I'm pretty excited about it though because it has some very nice features and is the cheapest BMS I've seen. Its just a little over $7/cell in materials for my 16 cell setup and gets cheaper as you add cells. The current design is made for my PHEV and will need some tweaking for a full electric car though.
http://www.evalbum.com/2984
Old 07-06-2012, 06:53 PM
EVPowers EVPowers is offline
EVPowers is on a distinguished road
Default Re: Mottcell 39Ah cell test results with PowerLab6
Hey Daox, great to see this stuff. Been a while since I though about Mottcells.
Actually your post reminded me that I have a bunch of those around here as well.
I just got my PowerLab8. Any idea if the profile you used can be used on a Powerlab8?
I haven't programmed anything in yet, and am looking to try not to have to start from a blank slate.
Eric Powers
Green Drive Expo
San Francisco Bay Area - September 15
Madison, WI - July 20 & 21, 2013
www.GreenDriveExpo.com
Old 07-07-2012, 06:21 AM
Daox's Avatar
I believe that you could probably use the profile I have. I would send it to you, but I am out of town for the weekend. However, setting up the charger isn't a huge ordeal. IIRC you select the cell chemistry, set the high/low voltage, and then select the max charge and discharge amps.
To familiarize yourself with the charger's software, I suggest finding the videos on the revolectrix site. Those got me going pretty quickly.
Old 07-07-2012, 02:10 PM
I'll take a look at those and go from there.
Thanks.
Eric Powers
Green Drive Expo
