Old 07-17-2012, 12:15 AM
lowcrawler lowcrawler is offline
lowcrawler is on a distinguished road
Default Re: How often to charge...
Originally Posted by Jesse67 View Post
With such a short commute and charging only to 3.5V your cells should last a long time, unless you drag race to work and back everyday....
Haha... yeah.
Well, my new property (which I just bought) is only 3 miles to work... and it's almost all 65mph freeway (litterally, my workplace is the second building off the exit and my new house is like the 7th house off the exit)... so that's like a drag race.
(actually, that's one reason why my pack is so oversized -- so I can run on the freeway without being at too high of a 'C' rate)
Old 07-17-2012, 06:30 AM
Jesse67 Jesse67 is offline
Jesse67 is on a distinguished road
Well any environmentally minded person like myself (tree hugger) should be asking you why you don't bike to work with a 3 mile commute.... that said I understand the joys of biking in traffic through industrial areas and fully realize its not for everyone.
It would be interesting if there was some more hard data on this, pay more for a large pack to have lower C rates and theoretically longer cell life, or pay less initially for a smaller pack which is worked a little harder but may not last as long? With less weight though the actual current draw and thus Ah draw would be less and the cells wouldn't have to work as hard as you might think. I would say you want your cells to be worn out from use just before they become no longer useful due to age, but you want this to be far enough in the future so your replacement pack is only a fraction of the initial price with 3 x the performance...whenever this will be I have no idea.
The mini truck is using 2 1/2 year old (calander life) 100Ah TS cells, 24 of them, and our current limit is at 450A which gives reasonable acceleration but it's also about as much as I can draw without the cell voltages sagging quite low, normal draw is around 100A. I would say these are being worked pretty hard, the range is only 50 km by design to keep the cell cost low. They only have maybe 1000km on them so we'll see how they hold up. My daily commute uses between 25-30Ah (or about an extra 500 calories when I bike...) so I have the same choices you have. I can technically drive to work for three days on one charge but I'll likely charge every day. I personnally tend to do better with frequent snacks as well, I get much less grumpy.
Currently driving a 92 Daihatsu Hijet conversion, 4wd, direct drive AC50, 24 x 100Ah TS cells. 50km range. Car sharing helps with the cost!
www.jessetufts.wordpress.com
Old 07-17-2012, 08:52 AM
Yeah, it's 3 miles on the freeway... nearly 6 if I bike. Still reasonable distance-wise, but only when it's between 35-60 or so degrees. Hotter and I arrive sweaty, cooler and it's too cold. ... and only when there is no threat of rain all day ... and only when it's not snowing or icy. ... and only when I don't have a meeting where my appearance matters... etc.
Biking is a GREAT option, but it has limited use in a state like MN due to the weather extremes. (it was triple digits here yesterday with the high humidity (humidity is generally high in MN anyway)... and it's below freezing for roughly 4-5 months of the year.
Even as-is, I'm pulling 2-4C pretty consistently. I felt 15kwh was about the smallest I could go and not be over-stressing the batteries.
Interesting idea, though. I wish we had SOME data on calendar life... I mean, as far as I know, we don't even have estimates... do we?
less [cells] and the cells wouldn't have to work as hard as you might think.
My pack isn't a huge percentage of my entire car weight -- only about 15-20%. Removing cells is going to shrink pack size (and increase C) at a rate faster than weight is removed... no?
Yeah, I'm leaning that way too....
Old 07-17-2012, 09:08 AM
dtbaker's Avatar
dtbaker dtbaker is offline
dtbaker is on a distinguished road
It would be interesting if there was some more hard data on this, pay more for a large pack to have lower C rates and theoretically longer cell life, .... I'll likely charge every day. ... much less grumpy.
extrapolating manufacturing estimates on cycle life as affected by C rate in either charge or discharge, and %DOD..... It is logical that designing with a pack 'oversize' on range to obtain average C discharge no more than 2C with only occasional accel to 4C or 5C to avoid internal heating, and %DOD no more than 50% or 60% with daily charge will likely provide *much* longer life.
HOW much longer under 'real use', I don't think we'll know for a couple more years, until the early adopters here start posting decreasing capacity on 'normal use' packs.... but the goal I think would be to find a pack size yielding 10+ year, or 100k-ish miles which would make the pack essentially a 'lifetime' pack for a given donor.
Dan
http://www.envirokarma.org/ev - '97 Suzuki Swift
http://www.envirokarma.org/ev2_mx5e - '94 Mazda MX5 Miata
