DIY Electric Car Forums > EV Conversions and Builds > EV Performance
Old 06-25-2012, 12:31 PM
spdas's Avatar
spdas spdas is offline
spdas is an unknown quantity at this point
Default Zilla behavior
Aloha, all. In regards to my Zilla performance (With my Yaris (Calb 46x180, Zilla, Warp @2700#weight), I get a kick when I reach about 2900 rpm. It pulls strong, at lower rpm, but at 2900 rpm, there is a shudder and it gets a kick/higher power. What is causing this?
thanks
Francis
Old 07-17-2012, 05:58 PM
GizmoEV's Avatar
GizmoEV GizmoEV is offline
GizmoEV is on a distinguished road
Default Re: Zilla behavior
Have you checked the resistance of your throttle pot? Is it smooth over the whole range? Maybe get something to monitor the output of the Zilla to see if there is anything strange going on from the Zilla's perspective. Check out http://www.evgear.com.au/zillaview.html
Old 07-25-2012, 07:09 PM
John Metric's Avatar
John Metric John Metric is offline
John Metric is on a distinguished road
switch from Series to Parallel?
get zillaview, send the txt file it creates to someone with a hex code converter (like me) and get the actual change in volts and amps charted when this occurrs. will tell you exactly whats going on.
Check your pedal percentage, make sure it is smooth and has a travel limit stop
Metric ampahaulic.com
DCP 9s-1/4mi 155mph-1mi
A&B 5s-1/8mi
LoneStar EV Racing
DIY DCP A&B
Old 07-25-2012, 09:11 PM
EVfun's Avatar
EVfun EVfun is offline
EVfun is on a distinguished road
The Curtis controllers used to have a slight kick right as they came out of current limit. There is some minimum off time when the controller is switching so there is a jump when going from that off time to zero off time. The thing is, I've never felt my Zilla do that in my buggy (like the Curtis used to.)
