FS: EMW EV Android Dashboard $235obo and Toshiba 10.1" $200
New never used. I bought it but decide to go another route. It's is brand new and never used.
I also have a Toshiba 10.1" tablet that I bought and the most use I have put into it is just installing the software that I will sell for $200. Buyer pay shipping or pick up in Parker, CO.
Thanks,
Kerry
EMW EV Android Dashboard - Base Edition
Monitor the Electric Vehicle dynamic characteristics on any Android device.
Connect the sensor board hardware to your battery pack following the instructions in the manual. Install the app on any Android device (Android 2.2 and later are supported, 3.2.1 and higher preferred) and establish Blue Tooth connection with the board. In this Base Edition you will be able to select to display any number of gauges from the following list: Instant Motor Power, Battery Voltage, Battery Current, Battery Remaining Charge Percentage, Miles Per Gallon Equivalent, Watt Hours Per Mile.
Position the gauges as you like anywhere on the screen and adjust their size to your convenience. Constant Bluetooth communication between the sensor board hardware and the Android app allows real-time visualization of the selected EV parameters. When the EV is parked for charging in your garage, take the Android device with you to monitor the charging state remotely (Battery Remaining Charge Percentage gauge).
The application can be installed on any number of Android devices allowing you the flexibility of checking the charging status of your vehicle from your phone while the main ‘EV Dashboard’ table is left in the car (only one blue tooth connection can be made at any time so you will have to disconnect / power down your in-car Android device in order to be able to connect another Android device for from-home monitoring).
Depending on the placement of the BlueTooth transmitter, you can get up to 60-70 feet of range for connection to Android.
Package includes:
Sender (sensor) Unit
Bluetooth Unit
7' Ethernet Cable
Software download (latest version, v1.4): V1.4 Android 2.3+ build
Software download (v1.2 - fallback if v1.4 does not work on your hardware): V1.2 Android 2.3+ build
Full detailed documentation: V1.2/4 Installation & User Manual
Installation videos on YouTube: Part 1 and Part 2
Known compatible devices
Note that these are the devices we or our customers have actually used successfully with our EV Dashboard. Virtually all full-featured Android devices should be compatible but we obviously have not tested them all. The list below will be expanded as we go. If you are our tester / customer and are successfully using EV Dashboard on a device not listed below, please let us know so we can add to the list below.
Tablets
ASUS Transformer 10.1" (EMW reference device)
Motorola Xoom 10.1" (EMW reference device)
Samsung Galaxy Tab 7" (EMW reference device)
Archos 101 G9
galaxy tab 7 plus
Toshiba 10.1"
Samsung I9100 (Galaxy S II in Europe)
Phones
Motorola DroidX (EMW reference device)
LG Optimus V
Please feel free to check out the application before your order and let us know what you think.
1994 Mazda Miata EV Conversion = It is ALIVE!
1986 GL1200 Trike, 196V, 9"ADC, SLAs = RETIRED
2011 Toyota Prius repalcing our 2008 Gen 2
2006 Jeep Liberty - Don't ask
Remember that your EV is only as clean as your power grid. Go SOLAR!
