Old 05-04-2012, 12:39 PM
RogerK RogerK is offline
RogerK is on a distinguished road
Default Re: Honda Goldwing Conversion
I am finally getting back to the project. Work and life is busy. I have all the parts ready for painting. That was a haul getting all that done. I needed body filler, fiberglassing, and many rounds of sanding. I will create a make shift paint booth and spray myself whent he weather is perfect. Not far off I am sure. Then hopefully my batteries will be here from China and I can get the final assembly and wiring done. Hope to get at least a 1/2 season of riding in.
Old 06-04-2012, 07:48 AM
I have the bike painted and polished. I am starting assembly, and the batterties are now in.
Old 07-17-2012, 07:54 PM
I went for the first ride tonight! I didn't go far, there are a few issues and don't have a lot of trust in my BMS yet. But the bike flew! Quiet, smooth, and plenty power! Can't wait to get finished and on the road.
Old 08-08-2012, 12:02 PM
Darxus Darxus is offline
Darxus is on a distinguished road
Nice!
More photos? Estimated range?
Did you cut out any of the existing frame, or just add to it to get the motor and batteries in?
Electric cabin bike project
Old 11-21-2012, 09:11 PM
I haven't posted about my project in a while. The Goldwing is running and I am using it. I had quite a delay scewring around with a BMS for a few months. What a pain. Delicate circuit boards on every cell. A controller that kept faulting and no reset. Board popping when I tried to work on it. The company (Elithium) tried to help, but in the end they abamdoned me and didn't stand behind the product. My suggestion is - don't use a BMS. LiFePo batteries seem to stay balanced, and just run a wire to a terminal block and check then once in a while with a volt meter. YOu can always manually balance using a big resistor. Thats how I do it. Make sure your charge shuts down the pack, and make sure you don't drive it unti it's dead. Follow that and you're fine without a BMS.
As for the bike, it runs great! Up to 60 mph. Range still not fully known, but surely will depend on many factors like how hard it is pushed. I did go 35 miles (mostly country roads - 45-50 mph), and still had some spare. I would guess I'm well over 40 in town. Acceleration is good, except I need an idler or somehting because when I crank on it the belt jumps. I need more wrap.
All for now. I did post on You Tube. Type in Goldwing EV
Roger
