Originally Posted by xtreme cartz
When a battery is rated at 220ah for example, is this to 50% DOD or all the way drained?
Here's a URL with a quote from it below.
http://www.windsun.com/Batteries/Bat...le%20Batteries
"All deep cycle batteries are rated in amp-hours. An amp-hour is one amp for one hour, or 10 amps for 1/10 of an hour and so forth. It is
amps x hours. If you have something that pulls 20 amps, and you use it for 20 minutes, then the amp-hours used would be 20 (amps) x .333 (hours), or 6.67 AH. The accepted AH rating time period for batteries used in solar electric and backup power systems (and for nearly all deep cycle batteries) is the "
20 hour rate". This means that it is discharged down to 10.5 volts over a 20 hour period while the total actual amp-hours it supplies is measured."
