Only had the car and most major components since mid-March - been driving the BMW (and enjoying it - not very green of me, I know) since then, but now that it's warmer I've run out of excuses (like the car is now out of petrol. Forever).
Didn't get as far as I hoped (but then I guess having the engine out after an hour was a bit much to expect )
So I drained the radiator, but couldn't find the engine block coolant plug, which (after more research) turns out to be on the other side of the engine from where I was looking, and hidden below the oxygen sensor, of which I have to be careful apparently (since I want to sell the engine - anyone (NZ) want an M52 with 335k on the clock?). Tomorrow night, maybe...
I'm following the Bentley book to do the pull, but am finding that although it's complete, it does assume at least some knowledge (like what the exhaust side of the engine is - I thought they meant the exhaust side of the car, which is different). I at least know what they mean by "front of the car..."
Now to go move the jack stands - I think they're in a bad place...
(one thing is for sure - I'm going to know a lot more about cars after this...)
I'm doing a '96 bmw 316 myself and i can say both the bently and haynes manuals are rubbish. I'll give you a few pointers that i found. Firstly , pull the engine and gearbox as one unit. Forget removing the gearbox on its own. If you have the rubber coupler between the drive shaft and gearbox you'll need an 18mm deep socket , knuckle joint , 18mm spanner and a long power bar to shift the 3 clinch bolts. I couldnt stop the engine from turning even with the handbrake on so i removed the plugs and filled the cylinders with oil. Not an option for yourself as you want to sell the engine so i'd have a friend in the driver seat with both feet on the brake pedal.
Fuel tank removal is real fun. Forget the manuals unless you *really* want to sell the tank. Remove the driveshaft and disconnect the handbrake cables and pull them through. Then inside the car remove the back seat and the two hatches and cut everything in sight. Under the car chop the straps (forget trying to undo the bolts they will be rusted solid) then undo the center bolt. Tank will sit on the two trailing arm bushes. Get a good stout rope and wrap it around the center of the tank. Then get a few friends and go tug of war on its ass! Tank will fold in the center and squeeze out past the bushes. Emptying the tank is best done prior to engine removal by connecting a hose to the high pressure line at the fuel rail and holding the fuel pump relay closed with a croc clip. Be warned i did this and thought the tank was empty. Well it was except for the 4 gallons of fuel it still contained!
Not sure how much of this will apply to yourself but hope it helps. I have a few vids on youtube may be a help.
As you say - not an option. Although I did find a website where they were talking about preserving unused engines in a barrel of oil, so I guess it's not necessarily all bad...
All useful tips - in fact, tonight after work I removed the front bumper
I decided to leave the radiator for a bit - I need to do some easy jobs first to build up some confidence (and yes, I know it's not hard for you guys with your workshops and toolkits, but remember all my tools are bright and shiny! And Oh! for a double garage. Or even a single garage that I could get the car into...).
The grill/front panel is next - little baby steps for me. Hopefully the weekend will be fine...
(pictures later...) (not that a missing front bumper is very exciting for anyone except me, and maybe the guys at work with a sweepstake on when/if I finish this )
I think 3 series BMW's make great cars to convert.
Not sure about all the trouble described in removing the tank. Mine came out very easy. But then again none of the bolts on mine were rusted.
Good luck with the swap and I'll second the Bently manual being not very good. They haynes manual is ok (for the money) but does not cover much in depth.
If you haven't pulled the motor yet one tip I can give you is to leave the entire harness connected to the motor/trans until out of the car (just undo the big plug by the fuse box and remove the relays on the side of the fuse box, the cover attached in the middle of the car and the connectors to the DME). I cut mine of the motor when I did one car and after it was out realize how easy it would have been to remove the thing together.
Oh other thoughts. Leave the hood on just put in the full vertical position (may have to remove one screw that locks it out of this on the linkage if no one else has and not put it back). Also removing the bumper and nose panel make access much easier and does not take all that long.
We don't all have huge garages and workshops. I'm doing mine on an open air rubble driveway with tools and skills I haven't used in anger for nearly 2 decades.
It is amazing what is possible when you stop caring what the neighbours think of the developing 'junk yard' on their doorstep!
And at least you had the skills 20 years ago - I've never had them
Speaking of tools - do I actually need any of the special BMW tools I keep reading about (or is there always an alternative)? The one that concerns me most (so far) is the one for removing the fuel line connector, when I get to it...
Got the front grill and panel off, and finally bit the bullet and wiggled under the car far enough to find what I think is the engine block coolant drain plug. (By leaving the radiator cap on until I was back out from underneath, I managed to (mostly) avoid the toxic shower I read about - it slowed the flow down to a trickle) I'm not convinced it's all out, since it's nowhere near the 10 liters I apparently should have had (more like 6)...
Actually today someone suggested the power version - a-n-g-l-e-g-r-i-n-d-e-r... It was just after I mentioned having seen rusty exhaust bolts while crawling around underneath...
Radiator's out - ignored the book in the end and took the radiator out. Couldn't get the fan nut undone - requires a special tool (apart from the reverse-threaded spanner ) to hold the coolant pump stationary - my screwdriver didn't work - it bent, instead
Found some more of that pesky coolant, too - it was in the pipes...
Hey Crunchtime! good to see your project is underway. I'm in Lower Hutt too so if you need a hand or want to check out my project gimme a shout. I have a 2ton engine crane if you need to borrow it for lifting the engine out.
I'm working on my MX5 currently, a few steps ahead of you since I have my engine out now.
WRT tools, one of my best investments has been an air compressor + rattle gun (impact wrench), its great for undo'ing those rusty and seized bolts that you'll no doubt encounter.
Got some more stuff out: Disconnected the main loom (basically the way you suggested, Thaniel - thanks ); removed the heater switch and related pipes (found some more coolant, too).
I seem to be at the point of needing to disconnect the fuel lines (to remove the injector header before removing the inlet manifold before...) - any hints for this?
Learning all the time...
(Got to go let off the fireworks - it's Guy Fawkes night (or it was on Thursday, anyway...))
Looking at it I'm reminded i took of the throttle body just to not break it. To disconnect the fuel lines.....you don't need them. hack saw through the rubber lines. I don't remember how I did it but any rubber lines connecting to the engine I basically just cut through. To lift the motor out you can see in the picture I put the spreader bar cross wise and attached to the motor mount locations then a strap back to the trans to balance it. worked reasonably well.
Two cables run from the wiring box under the windscreen to the back. One is the oxygen sensor. it has 3 wires other is the reversing light switch with two wires.
So I cut the wire - it had 2 cores, so I guess the reversing-light-switch...
and now I can see that I didn't need to take out anything I took out yesterday (comes from slavishly following the book). oh well, live and learn...
Yes - I was intending to split the exhaust at the down pipe (if the bolts aren't too rusty - haven't got any of the "Special Tools" discussed above, yet), so I had that right at least
AC Compressor is the only other thing I think - I didn't get it drained before starting, so can't take it out... Don't intend to use it, though, at least initially until I see what the range is like...
Update 12-Nov-2009: Sure enough, the bolts are rusty I'm spraying WD40 every day until the weekend, then I'll have another go. If that doesn't work, I'll get a blowtorch, but I'd rather not have to (I don't like the lack of room for getting away from underneath in case of something catching fire...) Might borrow/buy some bigger/better stands and get the car up a bit higher, too - mine are pretty small...
Not much happening recently. Managed to get the exhaust manifold undone (took the blowtorch approach in the end, and didn't have much trouble after that. Oh, and a bit of pipe on the end of the wrench helped as well )
Ended up getting the Air-con drained - guy came round, took 15 minutes, charged me NZ$67.50 - worth it for the peace of mind, even if not strictly necessary.
Took the exhaust assembly off today - couldn't see any wires connected anywhere, so I guess I don't have any oxygen sensors (none up by the coolant plug either) Could this be correct?
Thanks guys - the car was NZ-new, and it appears that New Zealand was a bit slack back in '95 and didn't require all this fancy O2 monitoring etc. There are definitely no connections to the pipe, nor on the exhaust manifold that I have seen. I can see from the photo how the sensor should get in the way of removing the engine-block coolant-plug - this didn't happen either. I'm fairly sure there are none...
Good question - after another year of still embarrassingly slow progress:
Hooked up the the batteries (including BMS);
Driven up and down the driveway with a passenger and EV grin ;
Installed and tested the ceramic heater core;
Installed the ammeter and voltmeter temporarily (needs a permanent mounting solution) - ammeter doesn't work for some reason ;
Installed and tested the EVWorks FGD+ on the fuel gauge (but not for a full charge/disharge)
Made, installed but not tested a Hall-effect RPM sensor connecting to the tach (with switch to change between RPM, and Battery Amps from the FGD+);
Tested my new replacement Zivan controller chip - batteries charged to the required level at the required speed and then stopped, so it seems to be working correctly;
Wired and plumbed the PS pump (switch in cabin controlling a relay) and added ATF (Need to test it - hope it doesn't explode ATF everywhere );
Still to do:
Testing of various components (see above);
More insulation as required (terminals etc);
Waterproofing (i.e. probably a belly pan, front grill dam etc);
This is a old thread but id like to add theres a far easier way to remove a e36 fuel tank if you dont care to resell it. Drill a hole in it (carefully) . Use a air drill if your really paranoid . I wasnt . Let the fuel drain into a container. Stick a garden hose in the fuel filler wash the tank out a couple of times. Plug in your angle grinder. Cut the tank into two pieces. Remove the tank. No drive shaft lowering required. No brake cable to be moved. Of course you need to unscrew the caps under the rear seat and some other cables etc but that takes 5 minutes. This may not suit everyone but it worked for me.
Full of water, ok, but any fumes and pockets and it could be a bomb. Water & gas don't mix, so how to wash the gas out without detergent?
I'd also suggest a sawzall vs an angle grinder - if you're gunna blow yourself up, at least get your name in the paper as a failed catalytic converter theif.
SDU or M3 makes more sense up front. If not, relocate the inverter
