First of all, I would like to let you all know that all of your hard work has inspired me to start my conversion a year earlier than I initially planned.
My car is a 1972 Mini. I have owned it since 2005. The engine has smoked since I got it and I've been dreaming for years now about ways to get away from this nasty old oil puffing raga-motor.
For those of you who've had any experience with this car, you know that space is the main issue with it. The car was very well designed and wasted no space at all.
The Transmission:
Most folks think the stock trany isn't of much use. I mostly agree with this. It sits in the oil pan of the ICE. Basically, it is the oil pan. It also sits in kind of an awkward position. It's right in the middle. there is a few inches in front of it, and there is a few behind it but not really enough space to put any batteries or the controller.
I'm using it anyway:
The thing is, I am converting this car in two stages. I want to get rid of my other car so I am converting this car now. That way, I can drive it while I work on the car's more permanent AC system. That means that quick and dirty (AKA, fast and cheap) DC system for now.
Slap Chop:
A very nice gentleman I met at the EVVCON sold me a Curtis DC Controller with a contractor, heat sink and two fans already assembled. On top of that, he offered it to me at a very good price. Thanks Einar!
Coils and armatures:
I picked a D&D 6.7" motor (that's right, just one). It puts out a bit more torque @ 1600 RPM's than the stock ICE peak torque of 52 lb-ft @ 2700. The D&D would put out 80 ft-lbs @ 1600 RPM if I could give it another 83 amps.
Connecting Bits:
I am going to use a chain drive and nix the clutch. The output shaft of the motor and the input shaft of the gearbox were at a one-to-one ration so I am going to gear up the motor a bit. I want to have some usable torque at 65 MPH and I figure most people don't really use 1st gear. I'll aim for a about a 2-1 chain drive (calculations pending).
12V+:
I am currently working on the DC-DC Converter. I bought some 3.3V Vicor modules that I will wire the output in series for a max of around 20A @ 13.5VDC.
Hi Jaesin. Sounds like a good plan. I'll be watching this. Will you fabricate a new end plate for the gearbox or just modify the existing one? Last time I looked at the gearbox it seemed there might be enough room to fit in a chain drive if you used fairly small sprockets.
Just commenting to subscribe to the thread. As an aside, from my experience with bicycle chains, I would make sure that the drive chain could be serviced with a minimum of disassembling.
chain-drive will be fairly noisy... and you need to be sure you have a way to adjust tension as it wears. You may want to consider the rubber belt drives found on some of the big touring motorcycles; much quieter and no lube required.
With belt drive you will still need way to adjust the belt tension, correct? The distance between the motor and gearbox would still have to be adjusted.
aloha, looks like you got an original Cooper S. Why not repair it, sell it, and buy a regular Mini. In the US, Cooper S's in nice shape I see going for $25k+
Aloha, It is a strange model then. As the 998 is the later Cooper engine, 997 was first. But I think the Cooper S came with 998, 1071 and 1275 engines. I never heard of a Cooper or Cooper S with drum brakes in front. And it has the right hand Cooper S gas tank (making twin tanks). So it is a real oddity to me. Someone in the UK would have to figure it out then. But it will make a nice EV!
The twin tanks do look original. I tried looking up the VIN (MXA251 717-850N) one day but it wasn't conclusive. I think it might be Australian made (Near Perth). Made by Morris BMC. This is kind of a hunch. When I got the car, it had what looked like old New Zealand plates and the VIN doesn't look like a UK VIN. It was original (besides being repainted) with no rust at all. They did make a Cooper S model but I read AU cars had some different features. Maybe they ran drum brakes in AU.
Cooper S
started with a 1071cc large bore engine - there were 970cc and 1275cc variants - the last 1275cc S was made in 1971
It had hydrolastic suspension
The Cooper started with a 997cc and a pair of dinky disc brakes that were less effective than the drums
went to a 998cc with discs that were as good as the drums
The S came out with a pair of slightly larger discs
the 1275GT has a different block, crank, rods and bigger discs (need 12 inch wheels)
I think you have a mini 1000 with an extra tank! - is it hydrolastic?
If so remove the hydrolastic bits and fit the rubber suspension (preferably from a 1977 or later)
I don't think you will be able to sell it as a Cooper S
You seem to have a rod change gearbox - that came out in 1973 and has a completely different exhaust tunnel and much better driveshafts - much better my old 1430 used to bend the old rubber hardysplicers - I got used to changing them fast, the inboard CV joints are much better
Wow Duncan, Thanks for all the info.
Does that cover Aussie cars as well?
I read that they started installing roll up windows in Australia before they did on UK cars. Being that the environment is different, I imagine there are other inconsistencies as well.
I don't have hydrolastic suspension.
Whatever my car is, It's not a UK Cooper S so even if it was an Aussie Cooper S, It's still not worth what an original UK Cooper S is worth. By time I'm done with it, it will be very something completely different anyway. A custom Cooper E with adjustable suspension and all wheel disc brakes.
Hi Guys
The gearbox is a spare. I have the rest of the engine if anyone is interested in it (998cc "99H791P"). I need to get rid of it.
I will probably go by the local Mini supply shop to pick up the suspension parts on Thursday. Is there anything I will need to match the gearbox to my '72? I guess I will have to check the gearbox in the car before I go. What should I look for to tell which gearbox is in the car.
Hi Jaesin
I would be very wary of that coil spring set-up
The mini doughnuts are very progressive - they have to be because of the limited travel
the advert says Road handling will be similar to rubber cone suspension, but with a big improvement in ride quality.
- simply not possible with a steel spring
lot of money for a retrograde step
Why do you want discs on the back? - the drums have to be limited by the proportioning valve
Aussie minis
They did some strange things but not I think cooper S's
Gearboxes
The earliest gearbox had a meter long gearshift lever coming straight from the gearbox - horrible
The cooper gearbox had a nice aluminium extension going to a shorter gearlever,
(the cooper box has the extension bolted to the gearbox - the old 1100 had a similar unit bolted to the gearbox through a rubber mount)
in about 1972-73 the rod change gearbox came out this has two rods going back to a housing bolted into the exhaust tunnel - this gearbox also came with the inner CV joints
My 1430 had a cooper box with the diff bits changed to have the inner CV joints,(after I had broken a lot of the older joints)
One of the problems with the old minis was the engine/gearbox unit used to try and tear itself loose, - mainly torque reaction
The advantage of the old cooper box was the long aluminium extension gave a nice long lever to stop the engine from rotating
Look at your exhaust tunnel - the pre-rod change shells had a bulge near your left foot, in the very first minis there was a floor mounted switch there
the later exhaust tunnels are much squarer without the bulge
I think you can use the earlier shells for a rod change but you may need to make a mounting bracket and dress the exhaust tunnel out a bit
My 1430 went for about 40,000 miles then the 1430 A series was a bit tired so I replaced it with - a 2000cc Lancia twincam + holbay cams and a pair of webers
Fun days!
This is what I have. A long rectangular aluminum tunnel attached to the gearbox. Complete with floor hump by the driver's seat (RHD). I am not sure if the tunnel will attach to the rod change gearbox. It doesn't look like it.
As for brakes, the front drums are actually pretty good if well maintained. The 8.4" discs are a significant improvement. It's not worth doing much at the back, as the performance of the existing drums if well maintained is more than you can use – it's limited by the proportioning valve, as Duncan said.
I mainly wanted the rear discs for cosmetic and weight saving but I am going to hold off on all not essential upgrades for now. It's a good point to think about the cost of all this stuff. I was getting a little too excited about wasting money. hahaha.
The last couple of years have been hard on "Champ". I am going to need to do a fair bit of body panel work. I should definitely take care of that and get some new paint before wasting money on stuff I don't need.
I agree with Duncan about the coil setup and brakes. I've looked at doing this at the front and rear (with a beam subframe). The consensus on the UK mini forum is that the standard rubber doughnuts and brake setup are very good and you can waste a lot of time and money trying to improve on them. The most cost-effective way to improve handling is to fit new doughnuts and dampers, as the rubber doughnuts last about seven years before stiffening up. Since you'll be changing the weight distribution it's also worth fitting hi-los – replacement suspension cones that let you adjust the ride height front and back.
I'm fairly sure you'll also need the later drive shafts to mate with the pot (CV) joints on your replacement box.
There is one suspension mod I would recommend
Longer front lower suspension arm,
If you can get a blank you drill the tapered hole for the bottom ball joint 6mm further out otherwise you cut two arms and weld them together - they are H section so it is easy to fill the H with two reinforcing bars and weld the whole mess together
Another tip - don't try and use a sexy small steering wheel
a powerful mini has torque steer - it can rip a small wheel out of your hands
We used to laugh at the guys with the small wheels as it showed they were show not go
otherwise there is not a whole lot worth doing - unless you replace the whole suspension
The adjustable Hi-Lo's are useful but you can do the whole thing with washers and a file
(much easier with the Hi-los)
Replacement springs
The problem is the mini has a short wheel travel and small wheels -
the springs have to stop the wheel movement when you hit a bump before you hit the bump stops
(this is why soft springs sometimes feel very hard - you are hitting the stops)
A simple steel spring has a constant rate (lbs/inch) so if it is going to stop the movement in a short distance it must have a very high rate,
The rubber doughnuts have a rising rate - so they are softer in normal use but can still absorb that big bump
Steel springs don't work - the only reason these people are reporting otherwise is because they have spent the money or their old system was knackerred and the have fixed it at the same time
Malcom suggested replacing them with new ones - the early ones were stiffer, in 1977 the factory went to softer units
if you have 1972 units they are both stiff and old
If you have some spare ones some people used to soften them by drilling holes in the rubber
try about 4 off 1/2 inch holes - the holes will go a funny shape when you take the drill out - this is normal
If you have spares you can do a suck it and see
Later drive shafts on an older gearbox
I did this on my 1430
You have all of the bits you will need on the other gearbox, take the diff side covers off - I think you will need the diff output shafts
If you get a later disc brake setup you will need the CV's and drive shafts as well
Its all pretty clear when you get the bits together
Sracer advertises that the springs are progressive. http://www.sracer.com/catalog/products/srp001.htm. Maybe not as progressive as the cones. Who knows, it's hard to get specs for these things. I had new doughnuts on it when I got the car but maybe they were not late model replacements. It could be that the seller wasn't perfectly honest.
So I guess I will need to rebuild the diff to use the older output shafts because I don't really want to buy new CV joints and axles at the moment.
Maybe it's possible to get standard axles but the ones I have sourced so far are beefed up $500 units. Ouch!
You just need the front hubs and driveshafts off any post 1984 mini - they all have the disc brakes after 1984.
I think you will need 12 inch wheels - the Cooper S brakes that can be fitted in 10 inch rims are like hens teeth
The inboards CV's don't seem to wear out much - the outboard ones only fail when they get grit in them
The diff is dead easy - practice on the spare gearbox you have - just take off the side covers - undo the fore-aft bolts and it comes apart
You should check that your old diff has the same input gear - if it has just drop the new diff into your cooper box and bolt on the side covers - if it has a different gear swap the gear from your old diff first
Swap the diff over - swap the side covers and you have a cooper gearbox (I think they were also fitted to std minis for a few years - if you have close ratios it's a cooper unit) with inboard CV joints
I just wanted to leave a quick note about my project for anyone that is interested. I started my build a couple of months before I was scheduled to leave town for the winter.
Before I left the US, I picked up 30x 100AH Calbs. The 10KW pack will sit in the boot below the level of the hinges. I still have to make the battery box but everything measures up just fine.
I tried to cut the motor bracket at the shop but the FlowJet was having issues with the abrasive so I still have to finish some parts on the mill and the band saw then weld it up. If I were to do it again, I don't think I would bother with the FlowJet. There is a Tormach CNC mill I can use. I still have to pay per minute to use the FlowJet because of the abrasive and the crap-load of energy it uses but I can use the Tormach all I want with my own endmills.
I am in Thailand at the moment. I will be leaving for Peru next week then I will spend 3 months in Brazil, Argentina and Chile. If any of you are in South America and you are working on a project, I would love to come check it out so send me PM and I'll try to meet you if I am coming through your area.
I picked up 30 CALB 100AH Cells back in November. That is just about a 10 kW-h pack which will give me a maximum range of 50 miles. That's fine for me for now.
I did some measurements and discovered that all 30 cells will fit in the trunk (mostly below the floorboard). The sub-frame in the rear of the car has a relatively large unobstructed rectangular opening that will allow me to drop the battery box down into it. I can create a new floor in the trunk just above the battery box and it will still be below the hatch opening which means that I will still be able to haul lots of groceries in the boot.
It looks like the stock mini is a bit front heavy (front/rear = 64/36) or about 828 lbs in the front and 446lbs in the rear. I am estimating that I will loose 100 lbs in the front by replacing the stock motor with the air cooled electric powertrain which should give me 728 lbs in the front. I will also add 135 lbs to the rear ( Li batteries +220, gas tanks and stock battery -85) giving me around 581 in the rear. Total estimated weight will be 1309 lbs giving me a front/rear ratio of 56/44.
The car already corners like a champ but what differences should I expect with the new front to rear weight ratio as far as handling is concerned?
Hi Jaesin. Yes, the space in the rear subframe is just about right for 30 x 100 Ah cells. Those prismatic cells make packaging so much easier than any alternative, especially in a Mini. I've been struggling to find a way to fit a relatively small pack of cylindrical cells in the boot, and finally admitted defeat, so they're going in the rear seat space instead. The cells would have been so close to the boot lid that the slightest nudge would have meant disaster. The improved weight distribution has to be an advantage. I don't have any experience racing Minis, but would expect that it will reduce understeer without causing any unwanted tail happiness.
Last November, I tried to cut out my motor bracket parts on a malfunctioning flowjet cnc. After that failed to dice up my 1/2 inch 6061 stock, I decided to finish it up on the Tormach PCNC1100.
I am now back from a very long trip to SE Asia and South America and actively working on the mini.
So I have been spending my spare time using the Tormach and practicing my TIG welding skills. I tacked my motor bracket together and laid a couple of beads before deciding to let a pro finish it up. I wanted to be sure it was solid and my welds are lacking consistency at this point.
I am using a ANSI #50 roller chain rated a 1620 lbs working load. I was recently at a RE-Fuel races at Laguna Seca and I noticed that the Kleen Speed team switched from the belt drive they were using the year before to an ANSI #50 chain. I asked David Kichar (COO) about the switch and he said that chain ended up having less resistance and is quieter than the belt drive. Needless to say, I found some relief in that. http://www.kleenspeed.com/ev-x11/ <- For a look at the Kleen Speed car.
All in all the bracket is looking pretty good but I still have to do a bit of touching up work but it is functional as it sits.
I still have to fabricate a rear bracket for the motor and seal up the transmission so the oil doesn't go flying all over the place. I have a piece of aluminum plate that covers the top of the transmission and I have the stock end plate that will cover the bottom half of the chain drive. I just have to fabricate the oil cover for the top half of the chain drive.
You can see the chain adjustment mechanism in the second picture. I will have to lift the motor and re-tighten the bolts for now but I will probably add a tensioning bolt to be sure there is no slippage.
Great to see this Jaesin! I was very close to trying this myself, so it's good to see someone else have a go. The aluminium mount looks nice and solid and the Union Jack pattern on the end plate is a nice touch.
Did you end up going with the 2:1 sprocket ratio? I can see the top sprocket's a 22t, so 11t on the bottom?
Did you have a new input shaft made or just modify the existing one?
The bottom has a 10 tooth sprocket on it making it a 2.2:1. There is very limited space inside the stock end plate and the 11 tooth probably would have rubbed.
I also have an 18 tooth sprocket to try on top if this it feels like it is geared too high for the hills here in San Francisco I'll take the highest ratio I can get. I would like to be able to make use of 1st gear and get the highest possible speed in 4th. I am planning to add an additional fan for cooling the armature.
The 1 inch input shaft has splines about the same size as the keyway on the sprocket so I am making a custom key that will seat into one of the splines. We'll see if it holds. I'll make it a very tight fit. I may also pull the shaft and mill out one of the splines for a proper keyway which would probably be the better way to do it.
Thanks for the info Jaesin. I'll be interested to hear how the gearing works out. 2.2:1 does sound a bit high, but on the other hand most people seem to find that the stock first gear ratio is way too low to be useful.
I did a bit of reading about chain drives for my own conversion and one of the recommendations is to avoid using low tooth counts, as it leads to accelerated wear. I think a lot of the documentation is over-conservative though. If you look at most motorcycle drives they seem to be outside the recommended envelope for long life. You've also got the advantage of a sealed oil bath, which makes a big difference.
I went to the opposite extreme and used 3/8" duplex chain, which lets you use a higher tooth count but isn't as strong as 5/8". There's only one way to find out if it's strong enough...
That's useful feedback about chain versus belt from Kleenspeed. I've heard a couple of other people say that belt is noisy and runs hot, so I guess I'll stick with chain too.
You are definitely right about that from all I have read as well. If I have a failure, I know for sure it is going to be because of that damn sprocket. Not only is it too small, the mounting for it is less than ideal but it is the biggest one that would fit inside the stock end plate. We will see what happens.
The mounting bolts are there in the first pic because that cap is on a motorbike. I think it looks great on the bike but it would start to take over on the rear of a mini. I'm was just trying to show the Monza style cap.
I decided to take the first motion shaft out and mill a proper keyway.
It's killed two solid carbide ALTIN coated end mills so far. Now I wait for new ones to get here from shars.
I cut the transmission end plate and bell housing in half because the chain and sprocket didn't fit in the top half of the end plate. I still need the lower half because it has the transmission mount attached to it. I will have to weld in some reinforcements for it.
The chain is attached but things are a bit tight. I will do a bit of milling on the case around the idler gear bearing to allow a bit more space for the chain to move around on the sprocket. Everything is looking good though. I have another spacer for the lower sprocket I can try that will allow the chain to back off the transmission end plate a bit.
-Jaesin
