Another homebrew AC-controller - Page 101 - DIY Electric Car Forums
DIY Electric Car Forums > EV Conversions and Builds > Controllers
Old 10-26-2015, 03:09 PM
jackbauer's Avatar
jackbauer jackbauer is offline
jackbauer is on a distinguished road
Default Re: Another homebrew AC-controller
Well done tom. great to see the boards worked out Where do you source the honda inverters out of interest?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 1000 Amps, that's bad.
www.evbmw.com
www.e39ev.com
Advertisement
  #1002
Old 10-26-2015, 03:11 PM
Tomdb Tomdb is offline
Tomdb is on a distinguished road
Send a message via MSN to Tomdb
Japanese car recyclers here in the Netherlands, Inverter complete with bus caps in a nice package. They cost about 100 euros a piece.
Old 10-26-2015, 04:11 PM
Gurgel's Avatar
Gurgel Gurgel is offline
Gurgel is on a distinguished road
oh yeah! very easy , this price is comfortable for my pocket! but can you put some photo? thx
Old 10-28-2015, 03:07 PM
got it all in a box, unfortunately could not find a shorter one, i need 35mm in height for the connector. But i could only find 60mm tall ones.
The black box (on top), contains the main board +h103, is 113mmx190mmx61mm. I need the 190mm for cable management and an extra relay to switch the Honda Ima inverter on and off.
For testing this is fine. If there is enough interest, I could look into redesigning the main board to fit under the existing Cover of the Honda inverter. This is tricky due to the fact the large lump is the bus and snubber cap which is part of the cover.
Old 10-28-2015, 05:17 PM
coleasterling coleasterling is offline
coleasterling is on a distinguished road
Looking great, sir!!
Old 10-29-2015, 01:28 AM
jhuebner's Avatar
jhuebner jhuebner is offline
jhuebner is on a distinguished road
Thats a great source for a compatible power stage!
You are using the existing gate drivers, so in effect you only need the main board?
Old 10-29-2015, 11:22 AM
only the main board hooked up to the mainboard of the IMA inverter.
Just one resistor divider for the current sensor. 5v range to 3.3v range.
Old 10-29-2015, 11:37 AM
For fear of sounding dumb, I'm interested to see how this works at high currents. I read a few references to hardware over-current protection. Is it hooked up in a way that allows the main board to still control the ready signals to the gate drivers?
Old 10-29-2015, 11:40 AM
I have no clue what you mean about this? The overcurrent protection is based on the main board (added on board) and will just stop the pwm signal from reaching the gate drivers.
Its based on a logic gate comparing the feedback from the current sensor to a level set by the micro. So if the phase current exceeds the max it stops the pwm.
Old 10-29-2015, 11:59 AM
Sorry for the confusion there, I realized it doesn't make much sense, either.
The datasheets for similar gate driver chips from Hitachi reference hardware over-current protection in the driver chip. If it senses over current, it shuts down the driver and throws a fault.
One, I am wondering how that's handled in the ECN3082A Honda had made (and the whole driver board). And two, if the original main board sees a fault, how will that affect the drive with your new board on top?
Support DIY Electric Car
Sponsors
