Another homebrew AC-controller - Page 149 - DIY Electric Car Forums
DIY Electric Car Forums > EV Conversions and Builds > Controllers
Old 01-07-2017, 03:48 PM
PStechPaul's Avatar
PStechPaul PStechPaul is offline
PStechPaul will become famous soon enough
Lightbulb Re: Another homebrew AC-controller
I just read the parameters of one winding of a 1.5 HP 4 pole 3 phase motor:
R(100Hz) = 6.27 ohms
R(1kHz) = 27.9 ohms
R(10kHz) = 442 ohms
L(100Hz) = 30.7 mH
L(1kHz) = 27.4 mH
L(10kHz) = 18.5 mH
I'm not sure how that scales to an EV motor of, say, 30 HP, or to the current for use as a boost inductor, but let's say the EV charger was 30 amps while the 1.5 HP motor would be used at 1.5 amps (1 amp per HP). Also let's say the input is 72 VDC to be boosted 5x to 360 VDC. To get 360 VDC at 1.5 amps would require 7.5 amps from the 72 volt source. With 30 mH inductance and 72 volts it would take 7.5 * 30 / 72 = 3 mSec to get 7.5 amps peak, and a comparable time to transfer the energy to the output. So perhaps 10 mSec period or 100 Hz might work for such a boost converter. These are just off-the-wall calculations, but I doubt that the boost converter could run at any higher than 1 kHz.
Please check my calculations and assumptions, and perhaps take similar AC resistance and inductance readings on the motor you are using. I might run a simulation, or even try making a boost converter with the motor I have. The reading is just for one winding, so with two in parallel the inductance should be the same but resistance would be half, and with all three phases connected the values are difficult to determine, especially since the windings have a common core and interaction with the rotor.
Advertisement
  #1482
Old 01-07-2017, 05:00 PM
jhuebner's Avatar
jhuebner jhuebner is online now
jhuebner is on a distinguished road
Default Re: Another homebrew AC-controller
Well, practically I tried 17.8kHz with my forklift motor and 8.8kHz with my 18.5kW Lenze Motor. That worked as described earlier, 92%/96% efficiency.
I tried earlier with a 1.5kW 230V motor like you described, that didn't work brilliantly indeed. But thats not a practical EV motor anyway.
Old 01-10-2017, 02:07 PM
arber333 arber333 is online now
arber333 is on a distinguished road
Originally Posted by jhuebner View Post
Right, thats the idea. Of course in your example if you have 400V input your pack needs to be >564V discharged for it to work.
Just realized I need to handle the case when the inverter is still switched on and the user plugs in mains. A simple relay as in my first drawing would dump rectified mains on the closed bottom switch of the respective phase.
Well good luck with finding such nominal DC voltage (besides Johannes) at boost... I will probably try boost from single phase and if that works buck from 3phase. That should be interesting.
I have a solution for inverter still being active when AC comes online.
I used a simple 230Vac relay to trigger the Emgcy pin when AC is on. So as not to drive off when charging.
Johannes does your charger mode start only when the key is ON or anyway? Inverter should just get 12V somehow yes? Start pin is not needed for this.
A
Old 01-10-2017, 02:47 PM
jhuebner's Avatar
A local company has built a couple of Mercedes Sprinter Vans on 800V. But you're right, it's still a pretty exotic setup. At least until car makers realize it's easier to fast charge a HV battery than a LV battery.
Yeah but that way the charger won't start as you have disabled one of the inhibit pins. You would need just a short low pulse on the emgcy pin. Like connect it to both NO and NC contact and use the dead time. That way drive mode would be safely disabled. When charge mode is active you can't drive anyway.
Question remains: emgcy stop pin is 16Hz low pass filtered, so there is a small delay between AC coming on and PWM disable. I'm actually considering some kind delay-relay so AC into the rectifier arrives after (like 100ms) the disable pulse.
EDIT: this just got me thinking: I should check the startup time of my AC/DC converter for the aux battery, maybe that is around 100ms.
start pin is indeed not needed. Just 12V power to the inverter (and inhibit pins)
Old 01-11-2017, 02:10 AM
jackbauer's Avatar
jackbauer jackbauer is online now
jackbauer is on a distinguished road
Well yes my plan would be to boost single and buck three phase. Does the current software support buck mode also?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 1000 Amps, that's bad.
www.evbmw.com
www.e39ev.com
Old 01-11-2017, 02:15 AM
jhuebner's Avatar
Yep, buck is supported.
I'm working on my web site to have the information easily available.
Old 01-11-2017, 12:39 PM
jhuebner's Avatar
Website updated: http://johanneshuebner.com/quickcms/...arging,27.html
Old 01-11-2017, 01:08 PM
onegreenev's Avatar
onegreenev onegreenev is offline
onegreenev will become famous soon enoughonegreenev will become famous soon enough
Hoping to get back to my project here real soon. Nice to follow the charging abilities. Buck being the most desired for high current low voltage packs.
Change comes, one conversion at a time.
http://onegreenev.blogspot.com/
Old 01-11-2017, 01:18 PM
Tomdb Tomdb is offline
Tomdb is on a distinguished road
Send a message via MSN to Tomdb
Johannes, very clear update. I need to get a car built so I can actually start using my gathered EV components
I wonder how much power you could pull with one of these from a three phase charging station (EU one so 230v x 3). Should be 32 amps x 230 x 3.
Old 01-15-2017, 02:39 PM
dima dima is online now
dima is on a distinguished road
Johannes your website says Boost(4) Buck (5) but the firmware description says:
"chargemode 0=Off, 3=Boost, 4=Buck"
not to confuse with opmode that is also needs to be set same?
0=Off, 1=Run, 2=ManualRun, 3=Boost, 4=Buck, 5=Sine, 6=AcHeat
mistake somewhere on your website or firmware?
Support DIY Electric Car
Sponsors
