Another homebrew AC-controller - Page 51 - DIY Electric Car Forums
DIY Electric Car Forums > EV Conversions and Builds > Controllers
Old 10-11-2014, 01:12 AM
jhuebner's Avatar
jhuebner jhuebner is offline
jhuebner is on a distinguished road
Default Re: Another homebrew AC-controller
I have done an experimental speed controller. I'm away from my lab right now so I couldn't test it.
Here is what I changed:
param_prj.h:
Code:
    PARAM_ENTRY(idlespeed,   "rpm",     -100,   1000,   -100,   52  ) \
    PARAM_ENTRY(idlekp,      "",        0,      100,    1,      53  ) \
stm32_sine.c CalcAmpAndSlip:
Code:
   int idlespeed = parm_GetInt(PARAM_idlespeed);
   int speed = Encoder::GetSpeed();
   int speederr = idlespeed - speed;
   s32fp idlekp = parm_Get(PARAM_idlekp);
   s32fp potreg = MIN(FP_FROMINT(50), idlekp * speederr);
   s32fp potnom = MAX(potreg, parm_Get(VALUE_potnom));
So its a simple P-controller. It can assert a maximum of 50% throttle. As soon as the speed drops below idlespeed the controller will output a value that is larger than the current pot value and thus take over. The default value will always output a very negative pot value and therefor essentially disable the controller. potnom is no longer modified globally so the start inhibit logic will work.
The controller is configured by idlekp. Set it to a value that does not oscillate.
I left the newline unchanged for now.
You can download the binary here: http://johanneshuebner.com/stuff/stm32_sine_2.71.bin
Advertisement
  #502
Old 10-11-2014, 05:23 AM
jackbauer's Avatar
jackbauer jackbauer is offline
jackbauer is on a distinguished road
It works
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 1000 Amps, that's bad.
www.evbmw.com
www.e39ev.com
Old 10-11-2014, 09:55 AM
dcb dcb is offline
dcb is on a distinguished road
yah but he cheated If he ever starts FOCing around then idle will have to be re-implemented. But working is good too!
I don't know, but I'm not sure it is technically a P-controller if it doesn't remember some more information about previous errors/adjustments, I think idlekp goes under the heading of fudge factor
P Proportional Band = 100/gain
I Integral = 1/reset
D Derivative = rate = pre-ac
Disregard, you did say P-controller (not PID), never knew all my fudge factors had a fancy name
http://www.controlguru.com/wp/p62.html
Old 10-11-2014, 02:08 PM
jhuebner's Avatar
Yep, don't do PID if P does the job
Good to hear it works without prior testing
Old 10-12-2014, 04:14 AM
jackbauer's Avatar
Not sure if it saved the idle speed value. did a quick test yesterday evening and it didnt idle when powered up. Will check today and report back. Have some video on the way also.
www.evbmw.com
www.e39ev.com
Old 10-12-2014, 04:53 AM
Tony Bogs Tony Bogs is offline
Tony Bogs is on a distinguished road
Finally, speed control! That's more like it.
I disagree on Arduino. The Arduino Due has an Atmel ARM chip on board with all the major hardware goodies needed for an EV controller: sophisticated DMA, multi phase PWM with H/W protection, timers, it's all there.
The top Arduino software layer, that most engineers despise, is really very thin. Below it is a complete open source C/C++ ARM software framework.
And then there is the UDOO board www.udoo.org. It is a Ubuntu / Android mini PC combined with an Arduino Due on a single PCB.
Isn't it a ideal combination for a development system with a local PHP web interface?
Porting the software may take some effort. It's not that well documented.
But on the other hand, it also provides a great opportunity for speed control review, modification and reorganization.
Speed control. I like it.
Old 10-12-2014, 08:54 AM
dcb dcb is offline
I'm glad to see atmel catching up in the ARM department, but there are good reasons why engineering types don't like arduino for serious development.
But as far as doing web-style development on an android that talks to a microcontroller, that might be better served with a simple bluetooth/local port proxy. The php side isn't so interesting that interesting that it would be terribly missed, yet all the javascript functionality (graphing) can be retained.
That udoo is kinda ridiculous. Just need an apk or a jar file that is packaged nicely and a $5 bluetooth adapter (done).
You want to pull it into arduino, other folks want to pull it into mapleleaf, others want PIC, St has their own online arduino (on steroids) ide which plays with their neutrino...
I think you are at the point where you simply don't wanna learn a new toolchain, been there. But force yourself to get through it and make some binaries and you'll feel better, trust me, it is liberating. You won't feel like an arduino hostage come minion anymore, single-system-itis sucks.
http://www.diyelectriccar.com/forums...tes#post478826
Old 10-12-2014, 09:05 AM
Sure, for me no STM32/ bluetooth for development or torque control for normal driving.
Also, no IGBTs anymore.
Recently Cree presented this SiC mosfet module as a replacement for IGBT:
http://www.cree.com/Power/Landing-pa...lfbridgemodule
It can handle up to 1500A, limited bij the juction temperature.
Translates to up to 200 microsecs at 25 degrees C case.
Specified potential 183 kW at 850Vdc, 3phase, pf=0.98, 15 kHz, air cooled. Check it out.
Only negative point so far:
The gate requires +20/-5V voltage converter. But that's an easy fix.
Old 10-12-2014, 09:11 AM
O, and by the way, I'm an engineering type.
Old 10-12-2014, 11:16 AM
dcb dcb is offline
if you have the budget for brand spanking new cas300m12b2s then go for it. You probably don't need a diy controller in that case.
Not sure what you have against stm except unfamiliarity or some other agenda though, the speculative returns (kumbaya?) on the effort on porting it are hardly convincing though, and it isn't clear who does the porting and who gets the "benefits", or that all the cons of porting are even remotely being considered.
Support DIY Electric Car
Sponsors
