reconfiguring Tesla battery modules to 50v for TR4A project - DIY Electric Car Forums
Old 02-01-2016, 03:10 AM
alex d alex d is offline
alex d is on a distinguished road
Default reconfiguring Tesla battery modules to 50v for TR4A project
I have battery modules from a p85 Tesla. these are configured 6s74p producing 24.9v at 100% soc. I am only going to use 8 of the 16 modules as they weigh almost 26 kg each and I don't want to overload my Triumph TR4a (see my ev album profile). this will mean I have a 43kwh capacity which will give me a great range and keep the car at a stock weight as the total pack will be around 200kg, the only problem is that 8 modules will only provide 200v and my Siemens/ scottdrive 200 set-up ideally wants around 400v.
I have been thinking of ways to reconfigure each module from 6s74p to 12s37p. I was thinking about removing the aluminium plates that connect the cells together and taking the cells out to reorientate them appropriately and then laser cut some new redesigned plates to each side of the pack but this would take too long and I didn't want to destroy the pack as its held together with some pretty strong glue.
instead I have bought a router attachment for my dremel and I am going to cut the metal plates in half, whilst connected to the module. I am making sure not to cut the pre made links in the pack between the cells + and - terminals as this will save a considerable amount of spot welding.
I have finished routing my first test pack and now i need to spot weld bus bars in the pack to reconnect it appropriately. when i hold wires in the bars places as i have not done this yet, it registers 47.3v which is double the previous voltage so it seems to be a success!
I now need to but a spot welder so I can finish attaching the bus bars, do you think I should use aluminium or nickel plate for this?
Alex
Advertisement
Old 02-01-2016, 03:32 AM
Default Re: reconfiguring Tesla battery modules to 50v for TR4A project
these are the most recent pictures I have on my phone, ill take ones of the fully cut up module later, the red markings are the cut lines and the green markings show the pre made connection between a + and - terminal.
i plan on using an Orion bms, any thoughts here? the stock bms cant be used anyway unless the can is cracked and anyway it was designed for the previous configuration.
i'm hoping this configuration will allow me to pass 150kw of power to my motor and hopefully give around 160mi range, (the Tesla weighs over double and has double the capacity and seems to do 300mi ok )
any thoughts are very welcome!
Alex
Old 02-01-2016, 01:51 PM
AntronX AntronX is offline
AntronX is on a distinguished road
Good luck. I also have tesla modules and their low voltage makes AC conversion difficult. I was thinking to use 100KW DC-DC boost converter and keeping original modules intact.
Old 02-01-2016, 03:44 PM
Karter2 Karter2 is online now
Karter2 is on a distinguished road
As long as that 150kW is only in "bursts", you should be OK as that would only be ~ 380 amps from a ~ 120 Ahr pack.....so about 3C load peak.
But , if you are not using the original Tesla cooling systems, you should not expect to hold that for long.
Range is tricky to predict since it is much more a function of system efficiency...motor type, gearing, etc...and aero effects/ speed , driving style, road conditions, etc.
Remember, the Tesla has a much better aero design than a TR4 !
.......but not as much character !
Old 02-01-2016, 04:00 PM
dcb dcb is offline
dcb is on a distinguished road
what material are the plates?
I would suggest using a thin dremel cutoff wheel or thin saw so you leave the most material fwiw.
Old 02-02-2016, 09:49 AM
The plates are stamped saying aluminium grade 1100, I was thinking about using a cut ff wheel but there are too many curves. I am going to use a slightly smaller milling bit for the next ones but i want to prevent arcing and make sure they are not too close as well!
Old 02-02-2016, 09:54 AM
I guess im too late but do you have a link to the dc/dc converter you found? what is the efficiency of it?
ill probably only do the 150kw bursts very rarely as i can imagine it to be pretty scary in such a small car! the most important thing is that it can complete a 100mi trip as that is the furthest i ever seem to go!
is a bms advised, ill need to send my Orion off to have more wires added if so.
alex
Old 02-02-2016, 10:04 AM
electro wrks electro wrks is offline
electro wrks is on a distinguished road
If you are using an abrasive cut-off wheel (for the straight cuts), paraffin or candle wax rubbed on the wheel will keep it from loading up with aluminum. It may keep a carbide burr from loading-up too.
Old 02-04-2016, 12:41 PM
AD, what are the dimensions of the Tesla packs? Also, could you point out the 6, 74p areas in the packs? They look to be odd, random sized areas. Also, are the fusible link wires on both the positive and negative ends of the cells?
Old 02-06-2016, 04:50 PM
both ends of each cell have fusible links, the only part of the pack where you will see a plate connecting a cluster of 74 cells is on the plates that becomes the main positive and negative connection for the pack, all the other plates have 148 cells connected to them, this consists of the positive ends of a 74 cell cluster and the negative ends of a 74 cell cluster, these clusters are daisy-chained together with the appropriate plates on either side of the pack to form the module.
Tags
battery, cell, models, module, tesla
Support DIY Electric Car
Sponsors
