Just want to let you know what you were trying to do is possible, but current prototype cost more than USD 6000... So, USD 1500 per unit for production is perhaps possible. Someone already build a pair and is currently testing the 10 kW In-Wheel Motor on a real car in front of me as I am typing this. That's all I can say because if I tell you the details, somebody will kill me or sue me for millions of dollars in court. Confidential matter until the patent application is filed in several countries.
Just wait for the announcement soon.
Almost 6 months is more than enough time to file all the patents covering what you are witnessing. So, where's the beef? Everybody wants to know.
On going development work
This assembly has been in a Miata moves the car fine, work continues
I surprised after reading all 12 pages no one found this video
Mark
Hi Mark,
Where's the relevance to the thread topic? Do you intend to mount those motors in the wheels?
Regards,
major
If being direct drive and directly connected to the rim Via a shaft isn't a wheel motor then I'll delete my reply. All we did was offset the motor to eliminate unsprung weight, otherwise it retains all the attributes of a wheel motor. By your definition, does the motor have to be unsprung weight to be a wheel motor? How wide of a spacer can I use between the rim and motor before you no longer call it a wheel motor?
