Old 05-04-2012, 07:14 AM
crashedup crashedup is offline
crashedup is on a distinguished road
Default Re: EV High Voltage, Turning it on and off:
I DID READ THE LINK! WHAT I MEANT WAS!! Is there an input specifically for the ignition switch on the controller? And for maintenance did you put in some type of cutt off switch between pack and the rest of the system?
Old 05-04-2012, 08:33 AM
dladd dladd is offline
dladd is on a distinguished road
The input for the ignition switch is the key. Or maybe I'm not understanding your question? All you need to do is provide key on 12v power to the controller. It handles the rest. The Soliton is unique in that it has the contractors built it, so the pack cut off is not so obvious to the eye.
Most of us also have some kind of manual pack cut off (like a circuit breaker), but it's not used in daily usage. Just for maintenance or long term (anything over a few days, in my case) non-use.
1995 Saturn SL2 ev conversion
Old 05-04-2012, 09:55 AM
Ok thats it! I didnt know it was that simple.
Old 05-04-2012, 09:57 AM
Yabert's Avatar
Yabert Yabert is offline
Yabert is on a distinguished road
The two contactors inside the Soliton1 needed to be energized by 12v. If you cut the 12v, you cut the pack voltage to the controller.
In my case, this is related to the key switch.
My Smart Fortwo high power!
http://www.diyelectriccar.com/forums...ion-51472.html
Old 08-23-2012, 06:14 AM
mizlplix's Avatar
mizlplix mizlplix is offline
mizlplix will become famous soon enough
My 1238R Curtis controller does the same thing, it just needs a small, external relay to do this (it is not internal). +1 point to Evenetics for friendly design. -1 point to Curtis for being "old school".
OK, In my world, an "emergency" disconnect is just that. To be used in an emergency. It is not something I would use to turn a current load on and off several times per day.
SO, as long as the contact points are far enough apart to actually interrupt the current, I am not concerned if my switch has the correct voltage rating.
My pack disconnect switch is rated at 650 amps but at 48VDC. I expect it to have a dramatic event if ever called on to interrupt 130VDC (if there is a load on it). I have designed my switch accordingly. It is operated through a 24" long piece of PVC tubing. My hand is 2 feet away from the switch.
A charred hole where the switch used to be is not a real problem because it stopped a larger event from happening.
It only cost me $53.00
ivanbennett dot com/forum
AC Vehicle Propulsion Study Group
Old 10-26-2012, 09:24 PM
dragonsgate's Avatar
dragonsgate dragonsgate is offline
dragonsgate is on a distinguished road
I built an emergency cut off and it breaks the pack in the middle. Would it be better if it was on the end of the battery pack? The cable is hooked to a modified clutch peddle.
Tags
circuit breaker, contactor, fuse, high voltage, precharge
