Originally Posted by PhantomPholly
if you'd spent 1% of the time Googling it that you spent writing this disingenuous answer you would know.
You are incorrect.
I was not disingenuous at all.
Believe any piece of personal fiction you like. But your claim about me here is incorrect.
The source of tax revenue (or money printing or borrowing) used to pay for such programs is irrelevant to understanding what they are.
You misunderstand.
I will try to explain it again for you.
As I wrote above, I saw multiple questions woven together in your one question.
As I wrote above in post #2724 ... "Before being more specific than that ... In an effort to avoid another misunderstanding / miscommunication ... I would want to have better clarification and specification on the separate parts of that question... such as the following:" ... and I listed the parts I wanted clarification and specification on... this was honest ... straight forward ... and direct.
Understanding which programs you are counting is a separate issue from identifying the source of tax revenue... which is why I gave it a different # above ... Source of Tax was #2 ... identifying which programs was #1... they are different things ... but are both part of the question you asked.
You asked :
Simple question: Do you now understand that our entitlement programs alone consume more than our entire tax revenues, and that that trend will increase if significant change does not occur?
Here again ... the way you wrote it ... reads as "our entire tax revenue" ... which would fall back into being more than just federal tax revenue ... and would include 'entire' tax revenue ... all sources of tax revenue ... which would also include international tax revenue, state tax revenue , local tax revenue, etc... any possible source of tax revenue would fall into the category of "our entire tax revenue".
Previously when you made a similar broad statement about government tax revenue ... after a long series of back and forth it was determined that you did not intend it as you wrote it ... that you only 'intended' for the more limited federal tax revenue piece of the the 'entire' ... which is why this time instead of me just assuming you wrote what you meant ... I wanted to ask the question ... in order to make sure we were both talking about the same source of tax revenue.
They give zero return, they are not an investment.
Zero
Net return or zero return at all?
As we discussed previously there is a significant difference... and as discussed before I am not suggesting they have a 'net' return ... just like I don't think there is anything with greater than 100% system efficiency ... but no
net return is not the same as no return at all.
The time period is now
You misunderstand.
I'll try again.
The time period I asked about in #4 is the time period that the desired change is being attempted in.
For example:
Trying to accomplish the 'fair tax' style system you suggested previously from start to finish in less than 1 trillionth of 1 second ... is just not possible at all ... the time period is too small ... to try to go from start to finish of that same change over 1 year is very different than trying to accomplish that same change over 1,000 years.
The cost of not changing the trend is insolvency and total financial collapse, similar to the Weimar Republic.
That is a prediction ... bordering on fear mongering ... and like those who use similar fear mongering predictions about global warming ... I would also remind you to keep in mind the limits of what is known , vs what is not known.
This current discussion ... as far as I'm concerned ... has not yet reached the point of being able to make a decision about what the best course of action might be ... weather it is a direction you agree with or not ... I'm still trying to clarify and specify some of the multitude of questions ... or said another way ... the base ground work / foundation has not yet been laid.
Every once in a while you say something that makes me suspect that there is still a spark of reason in you. However, as soon as that happens you immediately post something like this as a follow up. Good luck you you.
Again with the insults?
I fail to see the point in your continuous stream of them ... but , whatever makes you happy ... as far as I'm concerned ... it only undermines your credibility.
As for the picture you posted ... which is different from previous lists you've posted ... you might have wanted to look a bit closer at it first.
The 3 items of the pie on the right in red $707B + $724B +$553B add up to = $1,984B ... which is less than the posted on the left side federal tax revenue ... of $2,200B.
If this graph is intended to represent identification for your question:
Than it is just simple math to see that your own numbers of $2.2T is larger than $1.984T ... so if this is the data you want to use ... under this data the answer is just ... no ... as in your presented data here shows that the programs indicated do not cost more than the federal tax revenue ~90% of it is rather larger ... but it is not as you wrote "more than" ... our "entire tax revenue" would make it an even smaller % once state tax revenue , local tax revenue , etc... were also added in.
