OK, this may be a very slow moving thread as I have to keep to a very small budget and with minimal time to do this but I might as well start somewhere.
My primary income is as a part time college teacher with the occasional furniture or carpentry commission. Most of my time is taken up with studying for my Masters Degree in environmental architecture, attending teacher training, renovating my house and voluntary working for the local amateur theatre.
I will be keeping my diesel estate (station wagon?) and two self built 1.5 ton trailers (one closed box, one open and extending) for the heavy long distance work.
I'll start with my EV requirements:
To seat 1+1 - ie. me and some luggage or me and a small friend.
To have a comfortable range of 35 miles to work - may need 70 miles if no charge point at work.
To drive 2/3 of that distance at 60+mph.
To be weather proof.
What I would like if I could afford and achieve it:
To seat 2 with luggage.
To have a comfortable range of 100 miles.
To cruise at 70mph for around 50 miles.
To be able to tow a small trailer occasionally
To look good.
I am happy to convert a suitable vehicle if I can find one. I am also keen to build from scratch.
I don't mind a reverse trike if it is light enough to have legislation benefits in the UK and improves range.
If I scratch build I am tempted to build a plywood monocoque on a steel subframe given that I am a cabinet maker.
Skills base:
I have restored Land Rovers and MGBs, built a racing MGB, built a 6x6 Land Rover with my own design 3 speed transfer box and three point suspension.
I am a qualified as a:
Motor vehicle mechanic and pipe welder
Electrician (house and light industrial)
Carpenter
Furniture maker
Part trained as a mechanical engineer
Can do some panel beating in steel and aluminium
My father is a electrical engineer trained by the British Army and for the first time he also thinks this is a good idea so he is on side.
I have mechanical hand tools, angle grinders, a couple of MMA welders and a pillar drill. I am currently looking for a small engineering lathe and then set up some work space at home.
The downside is that I have no garage, just a large driveway, and my workshop is for furniture making so no metal filings or greasy marks allowed. I am also not that knowledgeable about electronics - if I can't see how it works I generally don't understand it.
OK, so that is where I am at the moment. I think the plan is to find and recondition a forklift motor, sort out the motor side of the coupler, sort out a controller and then start looking for a vehicle to convert or to start scratch building. Once I have a vehicle or chassis plan I can look at getting batteries and chargers.
Throughout this process I will need to learn the requirements for the British IVA process to get anything other then a straight conversion legislated for road use.
Any advice from here onwards would be most welcome.
Thank you
