DIY Electric Car Forums > External Information > EVDL List
Old 09-28-2009, 10:45 AM
EVDL List EVDL List is offline
EVDL List Bot
EVDL List is on a distinguished road
Default Re: [EVDL] Jumpy Pots
I've had the same Curtis pot box in my EV for at least 3 years,
possibly up to 14 years old (I bought the car previously converted and
used). Currently my pot box is inside a weatherproof enclosure:
http://picasaweb.google.com/lh/photo/sby8m0mJDgKUTfUMTvYoVA?feat=3Ddirectli=
nk
it still works smoothly for me on a Kodiak controller
-Jon Glauser
http://jonglauser.blogspot.com
http://www.evalbum.com/555
[quote] soundboats <xxx@xxx.xxx.gov> wrote:
> Hello, I am trying to find out if anyone has had any luck in finding
> potentiometers that do not degrade with heavy use. I have tried the Cu=
rtis
> PB-6, a Chinese copy of the PB-6, and the Logisystem potboxes. All have
> suffered from the same degradation over time and last no more than 6-8
> months in heavy city and suburban driving (about 100 miles a week in stop
> and go traffic). The Logisystems potbox lasted only 2 months, the Curt=
is
> about 8 months, and the Chinese copy has been in for 6 months and showing
> signs of degradation.
> Initially all the potentiometers have a steady increase in resistance with
> the movement of the arm. However, the pots become progressively =93jum=
py,=94
> making driving difficult. I have measured the resistance and find that=
any
> small movement of the arm makes the resistance go up much higher for seco=
nd
> and then come down to what it should be. For example, if I have the ar=
m in
> a position that provides 1000 Ohms of resistance and move it just a few
> degrees the resistance jumps to 2500 Ohms before coming back down to 1200
> Ohms. This type of jump occurs at any setting of the arm and is not re=
lated
> to the controller. I have measured this jump when the pot boxes are
> disconnected from the controller as well.
> So, I am trying to find out if there is a brand of potentiometers that do
> not have this problem. I have found out that the resistance in these p=
ots
> is provided by a piecce of plastic, and I wonder if the plastic degrades
> with use. Any help would be welcome.
> Thanks,
> Tom Hruby
> View this message in context: http://www.nabble.com/Jumpy-Pots-tp25648568=
p25648568.html
> Sent from the Electric Vehicle Discussion List mailing list archive at Na=
bble.com.
> General EVDL support: http://evdl.org/help/
> Usage guidelines: http://evdl.org/help/index.html#conv
> Archives: http://evdl.org/archive/
> Subscription options: http://lists.sjsu.edu/mailman/listinfo/ev
EVDL List Bot
Hi Tom,
Yup, pot boxes will do that.
The bests solution is to change over to Hall effect ones, if your controller
supports it. I have yet to see one of those degrade at all.
Matt
-----Original Message-----
From: xxx@xxx.xxx.edu [mailto:xxx@xxx.xxx.edu] On Behalf
Of soundboats
Sent: Tuesday, 29 September 2009 12:32 AM
To: xxx@xxx.xxx.edu
Subject: [EVDL] Jumpy Pots
potentiometers that do not degrade with heavy use. I have tried the Curtis
and go traffic). The Logisystems potbox lasted only 2 months, the Curtis
the movement of the arm. However, the pots become progressively "jumpy,"
making driving difficult. I have measured the resistance and find that any
small movement of the arm makes the resistance go up much higher for second
and then come down to what it should be. For example, if I have the arm in
Ohms. This type of jump occurs at any setting of the arm and is not related
not have this problem. I have found out that the resistance in these pots
Thanks,
Tom Hruby
http://www.nabble.com/Jumpy-Pots-tp25648568p25648568.html
Nabble.com.
Old 09-28-2009, 10:55 AM
EVDL List Bot
ICBIaSBUb20gYW5kIEFsbDsKCiAgIEhlcmUgd2UgZ28gQUdBSU 4hIFRoZSAjJEAlXiYgcG90cyBh
cmUgYSBjcmFwcHkgd2F5IHRvIHJ1biAKY29udHJvbGxlcnMvY2 FycyEgQW5kIHNpbmNlIHRoZSBt
YW51ZmFjdHVyZXJzIGNhbid0IHNlZW0gdG8gZmluZCBERUNFTl QgCm9uZXMsIG9yIHdhbnQgdG8g
c3BlbmQgbW9yZSB0aGFuIDI5IGNlbnRzIGZvciBvbmUsIGJ1dC B0aGV5LCBsaWtlIHRoZSByZXN0
IApvZiB1cyAsV0VBUiBvdXQhVGhleSBrZWVwIG9uIGJlYXRpbm cgZGVhZCBob3JzZXMhICBUaGUg
SGFsbCBFZmZlY3QgCnNldHVwKGNoYW5naW5nIGluZHVjdGFuY2 UsIGJ5IHRocm90dGxlIHBvc2l0
aW9uKSBpcyBOYXR1cmVzIG1vc3QgcGVyZmVjdCAKY29udHJvbD sgTWFnbmV0aWMgZmllbGRzIHNp
bXBseSBET04nVCB3ZWFyIG91dCxwZXJpb2QhIFNvcnRhIGxpa2 UgZ3Jhdml0eSEgCkl0IE5FVkVS
IGxldHMgdXAgb24gdXMgRVZlcnMhIFdIWSB0aGUgSGVsbCBoYX NuJ3QgY29udHJvbGxlciBidWls
ZGVycyAKaGF2ZW4ndCBnb25lIHRvIE9USEVSIHRoYW4gY3JhcH B5IHBvdHMsIGlzIGJleW9uZCBt
ZT8gTGV0J3MgZ28gYmFjayB0byAKcGlzdG9uIGFpcmxpbmVycy BhbmQgc3RlYW0gMjAgQ2VudHVy
eSBMaW1pdGVkcz8gRmVoISBIYWQgdGhpcyBhcmd1bWVudCB3aX RoIApQZXRlciBTZW5rb3dza3kg
YWJvdXQgcmVidWlsZGluZyBSYXB0dXJlIENvbnRyb2xsZXJzLi BNSU5FIHRoYXQgaGUgZGlkIGZv
ciAKbWUsIHVzZXMgYSBIYWxsIEVmZmVjdChpdCBMT09LUyBsaW tlIGEgc29sbm9pZCkgYW5kIHdv
cmtzIEdSRUFUISBMYXRlciBoZSAKd2VudCBCQUNLIHRvIGEgUG 90IGJveCwgb24gRGF2ZSBPLidz
IFJhbmdlciwgYSBzdGVwIGJhY2t3YXJkPyBFVmVyeSBkYW1uIA pSYWRpbyBpbiBteSBob3VzZSBz
Y3JhcGVzIGFuZCBzY3JhdGNoZXMgb24gdGhlIHZvbHVtZSBjb2 50cm9sISBJIGtub3cgSSdtIApT
VVBQT1NFRCB0byB0aHJvdyByYWRpb3MgYXdheSBldmVyeSAyIH llYXJzLCBidXQgU1RJTEw/Cgog
ICAgTm90IGFuIEVFIGhlcmUsIFdIWSBpcyBpdCBoYXJkZXIgdG 8gc2V0IHVwIGEgY29udHJvbGxl
ciB0byBkbyBIYWxsIApFZmZlY3QgUkFUSEVSIHRoYW4gYSBQb3 QgQm94Pz9NYXliZSBpdCdzIGEg
bW9yZSBkaWZmaWN1bHQgZGVzaWduPyBNYXliZSAKc29tZWJvZH kgdGhhdCBrbm93cyB0aGlzIHN0
dWZmIGNvdWxkIGNoaW1lIGluPyBMZWU/IEdvdCB5dXIgZWFycyBvbj8gT3IgCmFuc3dlciB0aGlz
IGd1eXogcXVlc3Rpb24gaW4gdGhlIGZpcnN0IHBsYWNlLG0gYm Vmb3JlIEkgd2VudCBpbnRvIFJh
bnQgbW9kZT8KCiAgIFNlZXlhCgogICBCb2IKLS0tLS0gT3JpZ2 luYWwgTWVzc2FnZSAtLS0tLSAK
RnJvbTogInNvdW5kYm9hdHMiIDx0aHJ1NDYxQGVjeS53YS5nb3 Y+ClRvOiA8ZXZAbGlzdHMuc2pz
dS5lZHU+ClNlbnQ6IE1vbmRheSwgU2VwdGVtYmVyIDI4LCAyMD A5IDEyOjMxIFBNClN1YmplY3Q6
IFtFVkRMXSBKdW1weSBQb3RzCgoKPgo+IEhlbGxvLCBJIGFtIH RyeWluZyB0byBmaW5kIG91dCBp
ZiBhbnlvbmUgaGFzIGhhZCBhbnkgbHVjayBpbiBmaW5kaW5nCj 4gcG90ZW50aW9tZXRlcnMgdGhh
dCBkbyBub3QgZGVncmFkZSB3aXRoIGhlYXZ5IHVzZS4gIEkgaG F2ZSB0cmllZCB0aGUgCj4gQ3Vy
dGlzCj4gUEItNiwgYSBDaGluZXNlIGNvcHkgb2YgdGhlIFBCLT YsIGFuZCB0aGUgTG9naXN5c3Rl
bSBwb3Rib3hlcy4gIEFsbCBoYXZlCj4gc3VmZmVyZWQgZnJvbS B0aGUgc2FtZSBkZWdyYWRhdGlv
biBvdmVyIHRpbWUgYW5kIGxhc3Qgbm8gbW9yZSB0aGFuIDYtOA o+IG1vbnRocyBpbiBoZWF2eSBj
aXR5IGFuZCBzdWJ1cmJhbiBkcml2aW5nIChhYm91dCAxMDAgbW lsZXMgYSB3ZWVrIGluIHN0b3AK
PiBhbmQgZ28gdHJhZmZpYykuICBUaGUgTG9naXN5c3RlbXMgcG 90Ym94IGxhc3RlZCBvbmx5IDIg
bW9udGhzLCB0aGUgQ3VydGlzCj4gYWJvdXQgOCBtb250aHMsIG FuZCB0aGUgQ2hpbmVzZSBjb3B5
IGhhcyBiZWVuIGluIGZvciA2IG1vbnRocyBhbmQgc2hvd2luZw o+IHNpZ25zIG9mIGRlZ3JhZGF0
aW9uLgo+IEluaXRpYWxseSBhbGwgdGhlIHBvdGVudGlvbWV0ZX JzIGhhdmUgYSBzdGVhZHkgaW5j
cmVhc2UgaW4gcmVzaXN0YW5jZSB3aXRoCj4gdGhlIG1vdmVtZW 50IG9mIHRoZSBhcm0uICBIb3dl
dmVyLCB0aGUgcG90cyBiZWNvbWUgcHJvZ3Jlc3NpdmVseSDigJ xqdW1weSzigJ0KPiBtYWtpbmcg
ZHJpdmluZyBkaWZmaWN1bHQuICBJIGhhdmUgbWVhc3VyZWQgdG hlIHJlc2lzdGFuY2UgYW5kIGZp
bmQgdGhhdCAKPiBhbnkKPiBzbWFsbCBtb3ZlbWVudCBvZiB0aG UgYXJtIG1ha2VzIHRoZSByZXNp
c3RhbmNlIGdvIHVwIG11Y2ggaGlnaGVyIGZvciAKPiBzZWNvbm QKPiBhbmQgdGhlbiBjb21lIGRv
d24gdG8gd2hhdCBpdCBzaG91bGQgYmUuICBGb3IgZXhhbXBsZS wgaWYgSSBoYXZlIHRoZSBhcm0g
Cj4gaW4KPiBhIHBvc2l0aW9uIHRoYXQgcHJvdmlkZXMgMTAwMC BPaG1zIG9mIHJlc2lzdGFuY2Ug
YW5kIG1vdmUgaXQganVzdCBhIGZldwo+IGRlZ3JlZXMgdGhlIH Jlc2lzdGFuY2UganVtcHMgdG8g
MjUwMCBPaG1zIGJlZm9yZSBjb21pbmcgYmFjayBkb3duIHRvID EyMDAKPiBPaG1zLiAgVGhpcyB0
eXBlIG9mIGp1bXAgb2NjdXJzIGF0IGFueSBzZXR0aW5nIG9mIH RoZSBhcm0gYW5kIGlzIG5vdCAK
PiByZWxhdGVkCj4gdG8gdGhlIGNvbnRyb2xsZXIuICBJIGhhdm UgbWVhc3VyZWQgdGhpcyBqdW1w
IHdoZW4gdGhlIHBvdCBib3hlcyBhcmUKPiBkaXNjb25uZWN0ZW QgZnJvbSB0aGUgY29udHJvbGxl
ciBhcyB3ZWxsLgo+IFNvLCBJIGFtIHRyeWluZyB0byBmaW5kIG 91dCBpZiB0aGVyZSBpcyBhIGJy
YW5kIG9mIHBvdGVudGlvbWV0ZXJzIHRoYXQgZG8KPiBub3QgaG F2ZSB0aGlzIHByb2JsZW0uICBJ
IGhhdmUgZm91bmQgb3V0IHRoYXQgdGhlIHJlc2lzdGFuY2UgaW 4gdGhlc2UgcG90cwo+IGlzIHBy
b3ZpZGVkIGJ5IGEgcGllY2NlIG9mIHBsYXN0aWMsIGFuZCBJIH dvbmRlciBpZiB0aGUgcGxhc3Rp
YyBkZWdyYWRlcwo+IHdpdGggdXNlLiAgQW55IGhlbHAgd291bG QgYmUgd2VsY29tZS4KPiBUaGFu
a3MsCj4gVG9tIEhydWJ5Cj4KPiAtLSAKPiBWaWV3IHRoaXMgbW Vzc2FnZSBpbiBjb250ZXh0OiAK
PiBodHRwOi8vd3d3Lm5hYmJsZS5jb20vSnVtcHktUG90cy10cD I1NjQ4NTY4cDI1NjQ4NTY4Lmh0
bWwKPiBTZW50IGZyb20gdGhlIEVsZWN0cmljIFZlaGljbGUgRG lzY3Vzc2lvbiBMaXN0IG1haWxp
bmcgbGlzdCBhcmNoaXZlIGF0IAo+IE5hYmJsZS5jb20uCj4KPg o+IF9fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fCj4gR2VuZX JhbCBFVkRMIHN1cHBvcnQ6IGh0
dHA6Ly9ldmRsLm9yZy9oZWxwLwo+IFVzYWdlIGd1aWRlbGluZX M6IGh0dHA6Ly9ldmRsLm9yZy9o
ZWxwL2luZGV4Lmh0bWwjY29udgo+IEFyY2hpdmVzOiBodHRwOi 8vZXZkbC5vcmcvYXJjaGl2ZS8K
PiBTdWJzY3JpcHRpb24gb3B0aW9uczogaHR0cDovL2xpc3RzLn Nqc3UuZWR1L21haWxtYW4vbGlz
dGluZm8vZXYKPgo+IAoKX19fX19fX19fX19fX19fX19fX19fX1 9fX19fX19fX19fX19fX19fX19f
X19fX18KR2VuZXJhbCBFVkRMIHN1cHBvcnQ6IGh0dHA6Ly9ldm RsLm9yZy9oZWxwLwpVc2FnZSBn
dWlkZWxpbmVzOiBodHRwOi8vZXZkbC5vcmcvaGVscC9pbmRleC 5odG1sI2NvbnYKQXJjaGl2ZXM6
IGh0dHA6Ly9ldmRsLm9yZy9hcmNoaXZlLwpTdWJzY3JpcHRpb2 4gb3B0aW9uczogaHR0cDovL2xp
c3RzLnNqc3UuZWR1L21haWxtYW4vbGlzdGluZm8vZXYKCg==
EVDL List Bot
SGVsbG8gVG9tLAoKSSBoYXZlIGJlZW4gcnVubmluZyBteSBQQi 02IHBvdCB3aXRoIGEgWmlsbGEg
MUsgZm9yIGVpZ2h0IHllYXJzIG5vdyB3aXRoIG5vIApwcm9ibG VtIGFmdGVyIEkgcm90YXRlZCB0
aGUgc3ByaW5nIHRpZ2h0ZXIgdG8gYSBzdG9wIEkgc2NyZXcgaW 50byBvbmUgb2YgdGhlIApzY3Jl
dyBob2xlcyBmb3IgdGhlIGNvdmVyLgoKVGhpcyBhY2NlbGVyYX RvciBhY3Rpb24gd2FzIHRvbyBs
aWdodCBhbmQgZXZlcnkgdGltZSBJIHdlbnQgb3ZlciBhIGJ1bX AgaW4gCnRoZSBzdHJlZXQsIEkg
d291bGQgZ2V0IGEgc2xpZ2h0IGluY3JlYXNlIGluIG1vdG9yIG FtcGVyZS4gIEkgYWxzbyBhZGRl
ZCAKYW5vdGhlciBhY2NlbGVyYXRvciBzcHJpbmcgd2hpY2ggSS BjYW4gYWRqdXN0IGFzIG5lZWRl
ZCB0byB0aGUgYXJtIG9mIHRoZSAKUEItNi4KCk5vdyBhZnRlci BlaWdodCB5ZWFycywgb2YgZHJp
dmluZyBhdCB0aGUgZXhhY3Qgc2FtZSBwb3NpdGlvbiBvZiB0aG UgYnJ1c2ggCnBvc2l0aW9uIG9u
IHRoZSBwb3Qgd2hpY2ggaXMgYSBzdGVhZHkgc3BlZWQgYXQgMz AgbXBoLCB0aGlzIHNwb3Qgb24g
dGhlIHBvdCAKbWF5IGJlIG1vcmUgY2FyYm9uIHVwIHdoaWNoIG luY3JlYXNlcyB0aGUgcmVzaXN0
YW5jZSBhbmQgbm93IEkgZ2V0IGEgc21hbGwgCmRyb3AgaW4gbW 90b3IgYW1wZXJlLiBQdXNoaW5n
IHBhc3QgdGhhdCBzcG90LCBJIHRoZW4gZ2V0IGEgbGl0dGxlIG p1bXAgaW4gCm1vdG9yIGFtcGVy
ZS4KCkl0cyB0aW1lIHRvIHRha2Ugc29tZSBlbGVjdHJvbmljcy BjbGVhbmVyIHRvIGl0IGFuZCBz
ZWUgd2hhdCBoYXBwZW5zLgoKUm9sYW5kCgpXaGVuIEkgaGl0IH RoYXQgc2FtZSBwb3NpdGlvbiwg
SSBkbyBnZXQgYSBzbGlnaHQgaW5jcmVhc2Ugb2YgbW90b3IgYW 1wcwoKCi0tLS0tIE9yaWdpbmFs
IE1lc3NhZ2UgLS0tLS0gCkZyb206ICJzb3VuZGJvYXRzIiA8dG hydTQ2MUBlY3kud2EuZ292PgpU
bzogPGV2QGxpc3RzLnNqc3UuZWR1PgpTZW50OiBNb25kYXksIF NlcHRlbWJlciAyOCwgMjAwOSA5
OjMxIEFNClN1YmplY3Q6IFtFVkRMXSBKdW1weSBQb3RzCgoKPg o+IEhlbGxvLCBJIGFtIHRyeWlu
ZyB0byBmaW5kIG91dCBpZiBhbnlvbmUgaGFzIGhhZCBhbnkgbH VjayBpbiBmaW5kaW5nCj4gcG90
ZW50aW9tZXRlcnMgdGhhdCBkbyBub3QgZGVncmFkZSB3aXRoIG hlYXZ5IHVzZS4gIEkgaGF2ZSB0
cmllZCB0aGUgCj4gQ3VydGlzCj4gUEItNiwgYSBDaGluZXNlIG NvcHkgb2YgdGhlIFBCLTYsIGFu
ZCB0aGUgTG9naXN5c3RlbSBwb3Rib3hlcy4gIEFsbCBoYXZlCj 4gc3VmZmVyZWQgZnJvbSB0aGUg
c2FtZSBkZWdyYWRhdGlvbiBvdmVyIHRpbWUgYW5kIGxhc3Qgbm 8gbW9yZSB0aGFuIDYtOAo+IG1v
bnRocyBpbiBoZWF2eSBjaXR5IGFuZCBzdWJ1cmJhbiBkcml2aW 5nIChhYm91dCAxMDAgbWlsZXMg
YSB3ZWVrIGluIHN0b3AKPiBhbmQgZ28gdHJhZmZpYykuICBUaG UgTG9naXN5c3RlbXMgcG90Ym94
IGxhc3RlZCBvbmx5IDIgbW9udGhzLCB0aGUgQ3VydGlzCj4gYW JvdXQgOCBtb250aHMsIGFuZCB0
aGUgQ2hpbmVzZSBjb3B5IGhhcyBiZWVuIGluIGZvciA2IG1vbn RocyBhbmQgc2hvd2luZwo+IHNp
Z25zIG9mIGRlZ3JhZGF0aW9uLgo+IEluaXRpYWxseSBhbGwgdG hlIHBvdGVudGlvbWV0ZXJzIGhh
dmUgYSBzdGVhZHkgaW5jcmVhc2UgaW4gcmVzaXN0YW5jZSB3aX RoCj4gdGhlIG1vdmVtZW50IG9m
IHRoZSBhcm0uICBIb3dldmVyLCB0aGUgcG90cyBiZWNvbWUgcH JvZ3Jlc3NpdmVseSDigJxqdW1w
eSzigJ0KPiBtYWtpbmcgZHJpdmluZyBkaWZmaWN1bHQuICBJIG hhdmUgbWVhc3VyZWQgdGhlIHJl
c2lzdGFuY2UgYW5kIGZpbmQgdGhhdCAKPiBhbnkKPiBzbWFsbC Btb3ZlbWVudCBvZiB0aGUgYXJt
IG1ha2VzIHRoZSByZXNpc3RhbmNlIGdvIHVwIG11Y2ggaGlnaG VyIGZvciAKPiBzZWNvbmQKPiBh
bmQgdGhlbiBjb21lIGRvd24gdG8gd2hhdCBpdCBzaG91bGQgYm UuICBGb3IgZXhhbXBsZSwgaWYg
SSBoYXZlIHRoZSBhcm0gCj4gaW4KPiBhIHBvc2l0aW9uIHRoYX QgcHJvdmlkZXMgMTAwMCBPaG1z
IG9mIHJlc2lzdGFuY2UgYW5kIG1vdmUgaXQganVzdCBhIGZldw o+IGRlZ3JlZXMgdGhlIHJlc2lz
dGFuY2UganVtcHMgdG8gMjUwMCBPaG1zIGJlZm9yZSBjb21pbm cgYmFjayBkb3duIHRvIDEyMDAK
PiBPaG1zLiAgVGhpcyB0eXBlIG9mIGp1bXAgb2NjdXJzIGF0IG FueSBzZXR0aW5nIG9mIHRoZSBh
cm0gYW5kIGlzIG5vdCAKPiByZWxhdGVkCj4gdG8gdGhlIGNvbn Ryb2xsZXIuICBJIGhhdmUgbWVh
c3VyZWQgdGhpcyBqdW1wIHdoZW4gdGhlIHBvdCBib3hlcyBhcm UKPiBkaXNjb25uZWN0ZWQgZnJv
bSB0aGUgY29udHJvbGxlciBhcyB3ZWxsLgo+IFNvLCBJIGFtIH RyeWluZyB0byBmaW5kIG91dCBp
ZiB0aGVyZSBpcyBhIGJyYW5kIG9mIHBvdGVudGlvbWV0ZXJzIH RoYXQgZG8KPiBub3QgaGF2ZSB0
aGlzIHByb2JsZW0uICBJIGhhdmUgZm91bmQgb3V0IHRoYXQgdG hlIHJlc2lzdGFuY2UgaW4gdGhl
c2UgcG90cwo+IGlzIHByb3ZpZGVkIGJ5IGEgcGllY2NlIG9mIH BsYXN0aWMsIGFuZCBJIHdvbmRl
ciBpZiB0aGUgcGxhc3RpYyBkZWdyYWRlcwo+IHdpdGggdXNlLi AgQW55IGhlbHAgd291bGQgYmUg
d2VsY29tZS4KPiBUaGFua3MsCj4gVG9tIEhydWJ5Cj4KPiAtLS AKPiBWaWV3IHRoaXMgbWVzc2Fn
ZSBpbiBjb250ZXh0OiAKPiBodHRwOi8vd3d3Lm5hYmJsZS5jb2 0vSnVtcHktUG90cy10cDI1NjQ4
NTY4cDI1NjQ4NTY4Lmh0bWwKPiBTZW50IGZyb20gdGhlIEVsZW N0cmljIFZlaGljbGUgRGlzY3Vz
c2lvbiBMaXN0IG1haWxpbmcgbGlzdCBhcmNoaXZlIGF0IAo+IE 5hYmJsZS5jb20uCj4KPgo+IF9f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX1 9fX19fX19fCj4gR2VuZXJhbCBF
VkRMIHN1cHBvcnQ6IGh0dHA6Ly9ldmRsLm9yZy9oZWxwLwo+IF VzYWdlIGd1aWRlbGluZXM6IGh0
dHA6Ly9ldmRsLm9yZy9oZWxwL2luZGV4Lmh0bWwjY29udgo+IE FyY2hpdmVzOiBodHRwOi8vZXZk
bC5vcmcvYXJjaGl2ZS8KPiBTdWJzY3JpcHRpb24gb3B0aW9ucz ogaHR0cDovL2xpc3RzLnNqc3Uu
ZWR1L21haWxtYW4vbGlzdGluZm8vZXYKPgo+IAoKX19fX19fX1 9fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX18KR2VuZXJhbCBFVkRMIHN1cH BvcnQ6IGh0dHA6Ly9ldmRsLm9y
Zy9oZWxwLwpVc2FnZSBndWlkZWxpbmVzOiBodHRwOi8vZXZkbC 5vcmcvaGVscC9pbmRleC5odG1s
I2NvbnYKQXJjaGl2ZXM6IGh0dHA6Ly9ldmRsLm9yZy9hcmNoaX ZlLwpTdWJzY3JpcHRpb24gb3B0
aW9uczogaHR0cDovL2xpc3RzLnNqc3UuZWR1L21haWxtYW4vbG lzdGluZm8vZXYKCg==
Old 09-28-2009, 11:05 AM
EVDL List Bot
T24gTW9uLCBTZXAgMjgsIDIwMDkgYXQgNTo1MiBQTSwgQm9iIF JpY2UgPGJvYnJpY2VAc25ldC5u
ZXQ+IHdyb3RlOgo+IMKgSGkgVG9tIGFuZCBBbGw7Cj4KPiDCoC BIZXJlIHdlIGdvIEFHQUlOISBU
aGUgIyRAJV4mIHBvdHMgYXJlIGEgY3JhcHB5IHdheSB0byBydW 4KPiBjb250cm9sbGVycy9jYXJz
ISBBbmQgc2luY2UgdGhlIG1hbnVmYWN0dXJlcnMgY2FuJ3Qgc2 VlbSB0byBmaW5kIERFQ0VOVAo+
IG9uZXMsIG9yIHdhbnQgdG8gc3BlbmQgbW9yZSB0aGFuIDI5IG NlbnRzIGZvciBvbmUsIGJ1dCB0
aGV5LCBsaWtlIHRoZSByZXN0Cj4gb2YgdXMgLFdFQVIgb3V0IV RoZXkga2VlcCBvbiBiZWF0aW5n
IGRlYWQgaG9yc2VzIQoKV2hvIGRvZXM/ICBBbGwgdGhlIFBTQSBjYXJzIHVzZSBhIGNvbmR1Y3Rp
dmUgcGxhc3RpYyBwb3Qgb24gdGhlCnRocm90dGxlIHBlZGFsLi AgVGhleSBkbyBub3Qgd2VhciBv
dXQuCgpUb3AgdGlwOiB1c2UgYSBnb29kIHF1YWxpdHkgY29uZH VjdGl2ZSBwbGFzdGljIHBvdCBk
ZXNpZ25lZCBmb3IKdGhyb3R0bGUgcGVkYWwgcG9zaXRpb24gc2 Vuc2luZy4gIFNwZW5kIGF0IGxl
YXN0ICQzMCwgdGhlbiBmb3JnZXQKYWJvdXQgaXQsIGJlY2F1c2 UgeW91J2xsIG5ldmVyIGhhdmUg
dG8gbG9vayBhdCBpdCBhZ2Fpbi4KCl9fX19fX19fX19fX19fX1 9fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fCkdlbmVyYWwgRVZETCBzdXBwb3J0OiBodH RwOi8vZXZkbC5vcmcvaGVscC8K
VXNhZ2UgZ3VpZGVsaW5lczogaHR0cDovL2V2ZGwub3JnL2hlbH AvaW5kZXguaHRtbCNjb252CkFy
Y2hpdmVzOiBodHRwOi8vZXZkbC5vcmcvYXJjaGl2ZS8KU3Vic2 NyaXB0aW9uIG9wdGlvbnM6IGh0
dHA6Ly9saXN0cy5zanN1LmVkdS9tYWlsbWFuL2xpc3RpbmZvL2 V2Cgo=
Old 09-28-2009, 11:45 AM
EVDL List Bot
Out of curiosity, what is a PSA car?
Matt =
Of Evan Tuer
Sent: Tuesday, 29 September 2009 12:58 AM
Subject: Re: [EVDL] Jumpy Pots
[quote] Bob Rice <xxx@xxx.xxx> wrote:
> Hi Tom and All;
> Here we go AGAIN! The #$@%^& pots are a crappy way to run =
> controllers/cars! And since the manufacturers can't seem to find =
> DECENT ones, or want to spend more than 29 cents for one, but they, =
> like the rest of us ,WEAR out!They keep on beating dead horses!
Who does? All the PSA cars use a conductive plastic pot on the throttle
pedal. They do not wear out.
Top tip: use a good quality conductive plastic pot designed for throttle
pedal position sensing. Spend at least $30, then forget about it, because
you'll never have to look at it again.
General EVDL support: http://evdl.org/help/ Usage guidelines:
Old 09-28-2009, 11:55 AM
EVDL List Bot
Peugeot-Citroen (with double dot on the last e)
http://en.wikipedia.org/wiki/PSA_Group =
Cor van de Water
Director HW & Systems Architecture Group Proxim Wireless
Corporation http://www.proxim.com
Email: xxx@xxx.xxx Private: http://www.cvandewater.com
Skype: cor_van_de_water IM: xxx@xxx.xxx
From: xxx@xxx.xxx.edu [mailto:xxx@xxx.xxx.edu] On Behal=
f Of Matt Lacey
Sent: Monday, September 28, 2009 11:14 PM
To: 'Electric Vehicle Discussion List'
Matt =
f Of Evan Tuer
> Hi Tom and All;
Who does? All the PSA cars use a conductive plastic pot on the throttle pe=
Top tip: use a good quality conductive plastic pot designed for throttle pe=
dal position sensing. Spend at least $30, then forget about it, because yo=
General EVDL support: http://evdl.org/help/ Usage guidelines: http://evdl.o=
Old 09-28-2009, 12:05 PM
EVDL List Bot
T24gTW9uLCBTZXAgMjgsIDIwMDkgYXQgNjo0NCBQTSwgTWF0dC BMYWNleSA8bWMubGFjZXlAaWlu
ZXQubmV0LmF1PiB3cm90ZToKPiBPdXQgb2YgY3VyaW9zaXR5LC B3aGF0IGlzIGEgUFNBIGNhcj8K
Cmh0dHA6Ly9lbi53aWtpcGVkaWEub3JnL3dpa2kvUFNBX1BldW dlb3RfQ2l0cm/Dq24KClRoZXkg
bWFkZSBhcm91bmQgMjAsMDAwIHJvYWQtZ29pbmcgRVYgdmVyc2 lvbnMgb2YgdGhlaXIgY2FycyBh
bmQgdmFucy4KCkFzIEkndmUgbWVudGlvbmVkIGJlZm9yZSwgdG hleSB1c2UgcG90ZW50aW9tZXRl
cnMgZnJvbSB0aGlzIG1ha2VyOgpodHRwOi8vd3d3LmFiZWxlY3 Ryb25pYy5jb20vZWxlY3Ryb25p
Yy1wcm9kdWN0cy5odG1sCgpUaGUgQ1AxNyByYW5nZSBJIGJlbG lldmUuICAgUmF0ZWQgZm9yIDMg
bWlsbGlvbiBjeWNsZXMuICBUaGlzCm91dC1saXZlcyB0aGUgY2 FyLCBzbyBpdCBzZWVtcyB0byBi
ZSBlbm91Z2ggKG1pbmUgdmFuIGlzIGF0IDExIHllYXJzCm9sZC BhbmQgODAsMDAwIG1pbGVzLCBm
b3IgZXhhbXBsZSkuCgpJZiB5b3UgZG9uJ3QgZmFuY3kgdGhhdC wgdXNlIGEgdGhyb3R0bGUgcG9z
aXRpb24gc2Vuc29yIGFzIGZvdW5kIG9uCmFueSBtb2Rlcm4gSU MgY2FyLiAgSXQncyBsaXRlcmFs
bHkgbWFkZSBmb3IgdGhlIGpvYi4KCl9fX19fX19fX19fX19fX1 9fX19fX19fX19fX19fX19fX19f
Old 09-28-2009, 12:35 PM
EVDL List Bot
The conductive pots WILL last longer - auto OEMs use them for throttle
position sensors (TPS). They're spec'd at 1 million cycles (5 million
"dither" cycles) and run $30 to $50 or more.
Be sure to check the datasheets before ordering - MOST are guaranteed to
be linear between 10% and 90% of the listed range. So a 5K pot may not go
below 500 Ohms or above 4500 Ohms. The sample I tried goes down to 390
Ohms. This may (or may not) cause your controller to always be a little
bit ON. It may also trigger a "high pedal lockout" condition on your
controller. YMMV.
HEPI pedals are awesome! I'm currently using them with Zilla controllers.
I cut cone pedal off and am using it like a potbox with the original
throttle cable. The other is a complete pedal mounted on the floorboard.
Would be nice to disassemble the complete pedals and shove the guts in a
standard PB-6 box...
-Adrian
> throttle pedal. They do not wear out.
> throttle pedal position sensing. Spend at least $30, then forget
> about it, because you'll never have to look at it again.
Old 09-28-2009, 01:45 PM
EVDL List Bot
Why not put a HE into a Curtis box... HE Pots are cheap enough, its just a
matter of finding one that has the right physical turning range...
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=1967060&k=Hall%20ef
fect
Bob Sisson
1993 Geo Metro Convertible Project
Gaithersburg MD
