[quote]On 30 Sep 2009 at 16:24, Gene Stopp wrote:
> What I ended up using were Vactecs:
> http://users.rcn.com/oakridge.ma.ultranet/Products/Vactrol.html
> These were very repeatable and predictable, and surprisingly fast. Of course
> for a pedal application, you would most likely drive the lamp with a voltage
> from a pot, which just brings us back to the original problem. However, I
> would think such a setup would nicely filter out scratchiness.
That's exactly the sort of solution I suggested the last time we had this
discussion on the EVDL.
Over 30 years ago, I used audio consoles in which the faders were based on
this idea. The dirt-cheap potentiometers on the console actually controlled
the brightness of incandescent lamps, which shone on CdS cells (LDRs). They
were made by Sparta, IIRC.
They turned oiut to be major headaches for the audio engineers. It was
almost impossible to keep the stereo channels in balance over the entire
range of the fader. This pretty clearly shows the inherent stability
problem.
However, I don't think that would matter very much for an EV controller.
The only problem I can see is if the lamp were to burn out. You'd need a
resistance-limiting safeguard to make sure the controller wouldn't go full
speed ahead in that instance. (The lamps in the Sparta consoles almost
never failed, btw; they were run well below their rated voltage.)
EVDL Administrator
General EVDL support: http://evdl.org/help/
Usage guidelines: http://evdl.org/help/index.html#conv
Archives: http://evdl.org/archive/
Subscription options: http://lists.sjsu.edu/mailman/listinfo/ev
