DIY Electric Car Forums > EV Conversions and Builds > Controllers
Old 10-23-2009, 02:31 PM
etischer etischer is offline
etischer will become famous soon enough
Default Electronic synchromesh shifting.
I came up with another nice feature on my AC motor controller. Shifting gears on my manual transmission takes about 4-6 seconds because I don't have a clutch. I have to wait for the motor to coast to the correct speed before engaging the next gear.
I now have a shift light which tells me when to shift. It works like this:
When I let off the throttle the motor RPM value is stored.
I shift the transmission into neutral
When the motor RPM is 66% of the stored RPM, my shift light will illuminate. This tells me the next gear is ready to engage.
My next upgrade will be to regeneratively brake the motor until the conditions are right to shift, then let the motor coast as I engage the next gear.
Old 10-23-2009, 04:31 PM
Russco Russco is offline
Russco is on a distinguished road
Default Re: Electronic synchromesh shifting.
Or you could add a real dry disc clutch just like manual transmission cars have had for 100 years. Can't beat a clutch for a safety disconnect let alone quick shifting!
Old 10-23-2009, 08:29 PM
Crash Crash is offline
Crash is on a distinguished road
I agree. I know that a clutch uses a few more amps, but the clutch really helps in safety and time. Put in a lightweight clutch/flywheel and save yourself some time. You may lose a whole mile out of all of your total range if your system is pretty efficient.
Old 10-23-2009, 08:38 PM
dimitri's Avatar
dimitri dimitri is online now
dimitri is on a distinguished road
You guys don't get it, any idiot can put a clutch in, but Eric is finding ways to add new functions to his AC controller is just too cool, so he is sharing.
Good stuff Eric, keep it up and keep sharing!
MiniBMS
E-Protege5 in the Garage
www.cleanpowerauto.com
"There are 3 kinds of liars: liars, damn liars and battery manufacturers"
Old 10-23-2009, 08:43 PM
Thanks dimitri =)
If I were re-designing my car from scratch, I might add a clutch. I have that funny helical gear to deal with, so it's not as easy as you might think. I get along just fine using only 2nd gear, but thought others might benefit from the idea.
Old 11-05-2009, 08:42 AM
neanderthal neanderthal is offline
neanderthal is on a distinguished road
wow very cool idea
