Originally Posted by david85
Did some more reading after I posted and it seems they do not have a pump. Somehow the heat alone causes a low volume circulation. Whats nice is they already have a heater, and thermostat so thats most of the work done. I found a blog called bimmerEV where he used a similar heater and he said he could get 100F air at the vents with it. I'm wondering if you put it close enough to the heater core that a pump isn't needed.
Don't understand why the thermostat would fail though. Thats not an electrical part (I don't think  ).
The 'stat would fail as it is an electrical switch to turn the heating element on and off. It will be rated to run at ac voltages adn high dc voltages would cause the contacts to fuse.
You could use the 'stat at 12v and then use the 12v circuit to trigger a high dc voltage solid state relay that will control the element.
Relying on thermal syphon circulation may not work due to the small size of the plumbing and the restriction of the heater core. You would just get locallised heating and then it will cut out while the water slowly circulated. It would be very inefficient.
