Old 11-03-2009, 06:11 PM
mpbug mpbug is offline
mpbug is on a distinguished road
Default Lovejoy connector for Bug tranny
I've just sheared my third P.O.S. Wilderness EV coupler and need a better option. I have a D&D ES31B motor coupled to a 73 VW superbeetle transmission (no clutch) I only have 72 volts and drive on flats. Any ideas? I think the Lovejoy connectors look great but don't know if they make one to fit on the splines coming out of the trans. Help! Mark
Old 11-04-2009, 05:48 AM
major major is offline
major is on a distinguished road
Default Re: Lovejoy connector for Bug tranny
Hi Mark,
What is P.O.S? Got pictures?
major
Old 11-04-2009, 05:51 AM
kek_63's Avatar
kek_63 kek_63 is offline
kek_63 is on a distinguished road
P.O.S. = piece of sh!t (in my world anyway)
Keith
Better than a kick in the ass with a frozen muk-luk!
Old 11-04-2009, 06:28 AM
JRP3's Avatar
JRP3 JRP3 is offline
JRP3 is on a distinguished road
I don't think lovejoys are up to it, from what I've read. If you're breaking couplers you may have alignment issues with your motor to tranny adapter.
Old 11-04-2009, 08:06 AM
The couplers I have used are made from the center of a clutch disc that is welded to a keyed coupler that fits my motor. The clutch disc is made from soft metal and 3/4" of spline on it.The tranny shaft has about 3" of spline sticking out in the bell housing.The soft metal splines are only about 1/16" of so deep and eventually grind off and the motor torque evetually spins them off completely. I am not generating a huge,huge amount of torque because I only have 72 volts and at best about 350 amps from my controller.I saw some guy on youtube or someplace using a lovejoy in a mazda with a Warp 9 and 120 volts. Anyone out there have a solution for me? Thanks, Mark P.S. I better not send picture of P.O.S.-I'm sure it will get censored!!
Old 11-04-2009, 08:25 AM
Woodsmith's Avatar
Woodsmith Woodsmith is offline
Woodsmith is on a distinguished road
How is it that your clutch disc centre is made from soft metal?
The clutch centre should be hard enough to handle the drive torque from the ICE without undue wear and tear.
If you look at Jackbauer's thread he has to heat up the corners of his clutch centre to get them soft enough to drill.
Old 11-04-2009, 11:59 PM
Bruce A Bruce A is offline
Bruce A is on a distinguished road
I had a similar problem with the center spline stripping out on a 72 volt system. I believe the reason is because I used a stock clutch hub and the metal is to soft, when I did my second coupler after the first one failed, I used a hub off a high performance clutch the metal is a harden kinda like tool steel, an I now run a 9" motor with 120 volts & pull over 600 amps at times so far it seems to be working fine.
Good Luck
