Old 11-06-2009, 11:29 PM
petenyma petenyma is online now
petenyma is on a distinguished road
Talking Got the EV grin!
I have been slowly working on my 66 MG Midget for the past 2 years and tonight I got it running and went around the block a few times!
I have to say I was surprised with the performance - it really moves!
Some general info:
- Zilla controller
- Impulse 9" DC motor. Original tranny with no clutch.
- 38 100AH Sky Energy batteries
- Chinoz charger
I still need to finish some body work and paint the car but I can see the light at the end of the tunnel...
I will post some pics as soon as I can find my camera.
Pete
Old 11-06-2009, 11:31 PM
Bottomfeeder's Avatar
Bottomfeeder Bottomfeeder is offline
Bottomfeeder is on a distinguished road
Default Re: Got the EV grin!
It sounds awesome!
I'm definitely interested in some pictures.
Old 11-07-2009, 06:33 AM
gdirwin gdirwin is offline
gdirwin is on a distinguished road
Congratulations! Looks like you built a little rocket...
Old 11-07-2009, 08:21 AM
RKM RKM is online now
RKM is on a distinguished road
Pete,
Congrats!! All the work, time, money and even the frustration pays off as soon as you press down with your right foot (my experience anyway).
Sounds like a great combination; light car, big controller and motor plus LiFePO4.
What is it like to shift? Mine is clutchless and was a really pleasant surprise.
Love to see pictures of the before and after paint.
Rob
"We could have saved the earth but we were too cheap." Kurt Vonnegut
Old 11-07-2009, 06:14 PM
Here are a few pics of the Midget today.
I have 12 of the 38 batteries under the hood and the remaining 26 under the trunk. The car sits about an inch lower in the front then back with this weight distribution.
As you can see I still have a lot of wiring clean up - this car was originally wired for positive earth so every bit of wiring has had to be torn out and redone.
Tonight I am charging the batteries completely for the first time.
Pete
Old 11-07-2009, 07:13 PM
everanger everanger is offline
everanger is on a distinguished road
very cool project.enjoy
Old 11-08-2009, 09:15 AM
After driving around the black a few more (20 at least ) times I can say that shifting without a clutch is not a problem - in fact I'm thinking I will rarely have to shift at all. It starts in 3rd gear with no problem. 2nd is just fun and will bark the tires if I get on it. And 1st is probably going to break something if I use it. So far my block isn't big enough to use 4th but my daily commute is about 12 miles of 60MPH road so I'm sure I will use it there.
Last night I fully charged the batteries for the first time. The charger ended with a voltage of 136v (3.57v per cell) this morning the pack is reading 128v. It seems a little low but well within the safe reign of these batteries.
I do not have a BMS yet but I do plan on using the Volt Blochers for the balancing. Then just using the low voltage warning on the Zilla for low battery. I will probably set that for around 115v and just stay away from the empty side of my pack.
Old 11-08-2009, 09:23 AM
Woodsmith's Avatar
Woodsmith Woodsmith is offline
Woodsmith is on a distinguished road
That is a lovely project to work on, I'v always had a soft spot for the MG Midget as it was the car my first girlfriend drove when she used to pick me up before I got my licence.
Old 11-08-2009, 10:12 AM
MN Driver MN Driver is offline
MN Driver is on a distinguished road
Very nice, I like the MG's and most other little british cars as well. Are the positive earth electronics also a 6 volt setup? That's gotta be tons of fun riding an MG with electric!
Old 11-09-2009, 12:03 PM
dimitri's Avatar
dimitri dimitri is offline
dimitri is on a distinguished road
Did you check every cell at the end of first charge? Do they all have same voltage? Initial balancing is pretty important since cells could have various SOC levels at first. Having shunts on during initial charge is pretty important, you are taking a risk of overcharging a cell or two.
I'm surprised pack voltage dropped that much overnight, seems that something is draining the pack, try to measure if there is any current going thru the pack while the car is off. Is there a precharge circuit for Zilla? Maybe precharge is leaking current to DC-DC converter, I had this issue until I realized what was going on.
What is the big black box that looks like old starter battery? Are you planning to replace it with small 12V aux battery?
Cool car BTW, congrats!
MiniBMS
E-Protege5 in the Garage
www.cleanpowerauto.com
"There are 3 kinds of liars: liars, damn liars and battery manufacturers"
