Originally Posted by Zak650
This is a question about cooling the PMAC-DS, ME0913 motor if it was installed in a VW bug. If a shroud were built to make a chamber around the cooling exhaust slots of the motor and then a good sized fan pulled a "vacuum" on that chamber do you feel it would work very well or be beneficial?
Thanks
Thanks Zak
Nope, axial air flow doesnt work.
I already tried it, It just moves heat from one coil to the other.
And def dont use a 0913 in a bug, too small.
try this, they can supply a water cooled version
http://kellycontroller.com/144v-12kw...or-p-1072.html
