DIY Electric Car Forums > EV Conversions and Builds > Electric Bikes
Old 01-27-2012, 03:35 AM
RoughRider RoughRider is offline
RoughRider is on a distinguished road
Default Re: RIPPERTON Electric track bike
WOOOW...141kg is realy good...
at the beginning of this thread i thought, that you were just another crazy guy with crazy ideas that will never get to life...
but now i see, that you are a very serious man
GOOD JOB
Old 01-27-2012, 09:22 AM
__Tango's Avatar
__Tango __Tango is offline
__Tango is on a distinguished road
Default
Btw. 12 seconds to swap packs. That's great. Do you expect to do that during a TTXGP type race? Will those lost 12 seconds + the slow down/pit speed time make up for the time you have to lay off the throttle?
'85 VF500 Conversion: http://electriceptor.wordpress.com
Old 01-28-2012, 02:24 PM
Zak650 Zak650 is offline
Zak650 is on a distinguished road
Ripperton,
Can you tell me the outside diameter of the motor's bearing on the output shaft? I'd like to drill some cooling holes in the motor without taking it apart.
Thanks,
Zak
Old 01-28-2012, 03:35 PM
RIPPERTON's Avatar
RIPPERTON RIPPERTON is offline
RIPPERTON is on a distinguished road
Originally Posted by Zak650 View Post
Ripperton,
Thanks,
Zak
Oh its much more complex than that Zak.
there are webbings in there that you dont want to drill through because you will weaken that face.
drill like this, 12 holes, 3 in each quadrant scribed by lines between each main bolt hole on a 80mm pcd.
Only prob is the bearing retainer plate has such a large diameter it will block most of the air you can get in through the holes. My plate is triangular, has flats cut into it between the 3 bolt holes
My YouTube Channel http://www.youtube.com/user/RIPPERTON?feature=mhee#p/u
Old 01-28-2012, 06:03 PM
Thanks, Do you have any photos of the inside of the case?
The webs run straight across from the outer mounting holes 180 degrees apart, correct?
Old 01-28-2012, 06:55 PM
RIPPERTON's Avatar
3 radial webs 120 apart. the top one is in line with the mount hole near the phase cables
Old 01-29-2012, 02:36 PM
Hi Ripperton,
Thanks for all your help and the information you have provided in this thread.
Do you have any power figures that you can provide to show what you have been able to wring out of one of these double stack motors? Have you ever put your bike on a dyno?
Thanks
Old 01-31-2012, 09:02 PM
RIPPERTON's Avatar
Zak havnt dynoed the bike yet but 164v x 600A = 98.4 kW at the controller minus 10% motor losses = 88.5kW wheel power.
the angle of the dangle = 12 degrees
adjusted the lean angle of the pack when supported by the pullout handle.
Old 01-31-2012, 09:11 PM
RIPPERTON's Avatar
working on the fitment of the pack when in the bike.
I want the pack to slide out easily also when the bike is laying on its side.
ie if the pack goes into meltdown whilst being ridden, the rider parks the bike in the gravel trap and drops it on its side then pulls the pack out onto the gravel then the marshals can hit the pack with powder and the rider wheels the bike over to the tire wall.
This alloy trim is the bottom wall of the air dam. the other 3 walls are on the pack. plastic fly screen is clamped between the trim and the cradle.
Old 02-01-2012, 08:45 AM
major's Avatar
major major is online now
major will become famous soon enoughmajor will become famous soon enough
Hi Ripper,
I like what you're doing However I am not convinced that a battery swap makes sense in the TTXGP brand of racing. I've been to all the US TTXGP events and haven't seen a venue where I think an advantage would be realized.
Now the opposite is true for another EV race with which I am involved. The kart race was 100 laps with many turns. We had about 8 kWh total battery by rule. We used split pack. During the race, swapped battery in 7 seconds
I also was involved with the Formula Lightning series back in the 90's. We were required to make battery exchange pit stops during most of the races. This was with Pb-Acid and the total on-board battery pack was about 1200 pounds. We were able to get the actual exchange time during race conditions down to about 17 seconds.
So I have some experience with battery exchange systems. Here are a couple of things I notice with your design. Containment in the vehicle should withstand crash conditions. I think this is about 8 g's. And the electric disconnect system needs to be spring loaded. It appears you use aluminum for the contacts. That will be trouble. I'd go with copper, silver or at least tin plated.
Just some of my observations. I've seen battery packs detach from vehicles during races and have seen fires result from disconnect failures
major
