DIY Electric Car Forums > EV Conversions and Builds > Controllers
Old 06-03-2010, 10:53 AM
albano's Avatar
albano albano is offline
albano is on a distinguished road
Default Soliton 1 controller
Hi! To all,
As anyone had the Soliton1 controller on the track?
Old 06-03-2010, 12:44 PM
TX_Dj's Avatar
TX_Dj TX_Dj is offline
SPAM Cop
TX_Dj is on a distinguished road
Default Re: Soliton 1 controller
Originally Posted by albano View Post
Hi! To all,
What kind of track? Drag strip? Autocross? Other?
I'm sure someone probably has... or it's probably been simulated.
cheers,
dj
"I'm No Expert!(TM)"
A fuel and his money are soon parted...
Old 06-03-2010, 01:04 PM
albano's Avatar
Drag strip.
I need to know, cause I need a strong and reliable controller for drag racing.
As I see we can't relies on Zilla, because the production is always on and off.
Albano
Old 06-03-2010, 04:34 PM
TX_Dj's Avatar
SPAM Cop
The Soliton 1, by everything I've seen, is a well designed, properly-engineered controller.
Talk to the manufacturer, they even give you a performance boost with the addition of a special "racing" warranty.
The guys who designed and build that controller are members on this forum.
cheers,
dj
Old 06-03-2010, 08:09 PM
electrabishi's Avatar
electrabishi electrabishi is offline
electrabishi is on a distinguished road
Drag strip.
Albano
Otmar has fully loaded Z2K's on his shelf. A large number of them for immediate purchase ;-)
Mike
"Three things cannot be long hidden: the sun, the moon, and the truth. "
Old 06-04-2010, 04:49 AM
Tesseract's Avatar
Tesseract Tesseract is offline
Tesseract will become famous soon enoughTesseract will become famous soon enough
Hey albano... no one uses a Soliton1 for drag racing, so far as I know. The Z2K still delivers the highest short-term power rating for now; we would only be able to compete with it if the race were longer than 1/4 mile.
We are currently designing a smaller version of the Soliton1 and are contemplating a larger version. The smaller version (300V/500A) is not really relevant here except to say that we expect it to be profitable very quickly...
In contrast, we suspect the larger version will have a very limited market but know it will be very costly to develop. As of now my estimate is that we might sell 2-4 "megawatt class" versions of the Soliton per year. That doesn't quite justify the development unless we charge a large premium for them (as in, much more expensive than simply buying two Soliton1s!)
So, while there is much talk of wanting a bigger, badder controller than even the Zilla Z2K, there doesn't appear to be much actual buying going of such going on.
Speaking of... hey Mike, are those Z2K's the same 14 that were built last year and featured prominently in this post:
http://www.diyelectriccar.com/forums...41&postcount=4
How many are left?
Chief Electron Herder for Evnetics, LLC.
Into EV's? Check out ChargedEVs Magazine
Old 06-04-2010, 12:17 PM
How many are left?
Nope. They are different ones. The ones Otmar is advertising are ones he had built prior to starting in with EVC. They still have the Cafe Electric Logo on them. And if I am not wrong the number of them is >10.
Mike
Old 06-04-2010, 04:59 PM
JRP3's Avatar
JRP3 JRP3 is offline
JRP3 will become famous soon enoughJRP3 will become famous soon enough
That seems an odd target. The 500A rating is low, suggesting a low controller price, but the 300V rating is high, and would require a high cell count while allowing higher performance. Is the 300V rating basically an artifact of the Soliton components and design, high voltage being easier/cheaper to achieve than high current?
Old 06-04-2010, 05:02 PM
JRP3's Avatar
And why are you building a larger version of the Soliton when I'm still waiting for my 3 phase AC controller I know you could sell more than 4 of those a year
Old 06-04-2010, 05:17 PM
Actually that would be a pretty good combo for a small car or truck even. While the cell count would be higher you could do with lower AH capacity. And with the higher pack voltage than what you put on the motor you should never run the controller at 100% duty cycle. Plus the lower amp draw is easier on the batteries for continued use (more so than with lead acid that exhibit Pukerts effect). I bought my Z1K in the -HV model just so I could do this. And when I had 192V pack in I could make it deliver a full 1000 amps to the motor and while still at relatively low RPM the battery current never got above 500-600 amps.
While I agree that 500 amps may be on the low side for anything other than a put put at 156V, with a 300V pack you could deliver full motor current to the motor and be easier on the batteries. There are benefits to these design parameters.
Mike
