Article Tools Display Modes
Default Frequently Asked Questions Regarding Electric Cars
Q: How much will it cost me to convert my car to electricity?
A: Using a standard DC system & components with average performance, you can expect to pay between $3000 and $6000 US. The price varies substantially depending on how fast and far you wish to drive. Some have converted cars for under $1000 US by using second-hand parts.
Q: How far can I drive in an EV?
A: Range is limited by budget. While a typical conversion may offer 60 miles on a charge, you will generally never get beyond 100 miles (160 km) using Lead-Acid batteries. The larger the Lead Acid battery pack the heavier it gets until the weight of the battery pack reaches the car’s limitations.
If you can afford Lithium batteries coupled with an AC system, range can be anywhere from 100 to 400 miles. Lithium batteries are not cheap however. A typical set with about 200 miles range might cost upwards of $20,000 US.
Q: How fast can an Electric Car go?
A: As fast as you like. Just like a gasoline powered car, you can modify and tune your EV until it leaves super-cars in it’s wake. While most EV’s are commuter cars, there are a handful that offer staggering performance. The most talked about would be the Tesla Roadster; an all-electric sports car with a 0-60mph time of 3.6 seconds and 245 miles of driving range between charges.
Q: How long does it take to charge?
A: On average, a home converted car will charge fully overnight. With Lead Acid batteries, 70% of the charging is done in the first 40% of charging time. The rest is the “topping up” stage of the charging process.
Technology is changing constantly however, and with new battery technology comes faster charging times. The newly released AltairNano Lithium batteries are supplied in the upcoming Phoenix SUT which can fast-charge completely in under ten minutes.
Q: Can alternators/generators be used to recharge the car while driving?
A: Unfortunately (other than making your EV a hybrid, or capable of regenerative breaking - see below) this is impossible, because it would violate one of the fundamental laws of physics. Basically, it means that you cannot get more energy out of a system than you put in. You will always use more power to turn the alternator or generator (eg, wind, or drive-shaft) than you could get back from the alternator or generator.
-> Using a generator while slowing and stopping your car (aka Regenerative Braking) is one option where you can recover extra range (up to 10% normally) by actuating a generator when your foot touches the brake pedal. Some Hybrids use this technology too.
Q: Are electric cars any more efficient and green than a normal car or do they just have a longer tailpipe (back to the power plant)?
Even when coupled with the standard fossil fuel burning power from the grid electric cars are substantially more efficient and better for the environment than their ICE counterparts. Tesla motors compares the efficiency from the source to the wheels of several efficient ICE and hybrid cars and found their electric car was twice as efficient as popular hybrids while producing a third of the emissions. Compared to a similar ICE roadster the Tesla was six times as efficient with a tenth of the emissions. The high efficiencies of electric power plants, batteries, controllers and motors means more of the power source ends up moving you down the road rather than heating up the air.
Created by KiwiEV, 11-23-2007 at 12:20 PM
5 Comments , 17932 Views
Old 11-24-2007, 10:55 AM
rbgrn's Avatar
rbgrn rbgrn is offline
rbgrn has disabled reputation
Default Re: Frequently Asked Questions Regarding Electric Cars
Nice. I think I'll link the FAQ link up on the menu bar to this wiki page.
www.diyelectriccar.com administrator
Green Web Publishing, LLC
Old 04-22-2009, 02:56 PM
PainBank PainBank is offline
PainBank is on a distinguished road
as to adding a generator to charge while driving, I disagree with the way the answer is stated.
Yes, you can add a generator, such as a tow behind module (provided everything is setup correctly, which might not be correct for a specific conversion) and yes it does then make the EV technically an HEV, but it can be done.
So I feel the answer is yes it can be done, but it depends on the setup of the EV and it technically is no longer an EV, but it can be done. Perhaps not easily, but still.
Old 04-23-2009, 10:13 AM
judebert's Avatar
judebert judebert is offline
judebert is on a distinguished road
The answer for "How long does it take to recharge?" is fundamentally flawed. The problem isn't really in the batteries: the problem is moving that much energy around. Even a small EV carries 15kWh; to replace that in ten minutes you'd need 90kW! For contrast, a home outlet provides 1.5kW max. You'd need a direct line to the power station, with a cord a foot in diameter, to charge an EV like that.
Old 06-20-2010, 08:50 AM
Chew Chew is offline
Chew is on a distinguished road
Yes, it can be done, however, according to the law of conservation of energy, you may only capable to recover about 10% of the total energy from the battery. Unless you always going downhill, that would be possible to recharge your battery pack from the regenerative process. In a simple word, there must be always an energy lost such as friction, heat, vibration, sound, etc that cannot be recovered.
Old 07-22-2010, 09:23 AM
rillip3 rillip3 is offline
rillip3 is on a distinguished road
Even if you had the juice available, PbA batteries (in particular, but this is true of all batteries) are designed to be charged at a certain voltage at a certain amperage. The internal resistance would cause them to explode if you put that much juice in them. Not having the power is a moot point when you would blow them up anyway.
Track my conversion progress at http://geo-storm-ev-conversion.blogspot.com
Article Tools
