So here is what I learned about motors from this site. I wanted to post a quick reference so newbs (like myself) do not have to sort through the sticky page.
When looking for a forklift motor:
Get a series wound motor because they have very high torque and handle abuse (over volting) a lot better.
Know the difference between a Spex motor and a Series wound.
When dealing with series wound forklift motors go for higher voltage. (36V may require advanced timing.)
Hp does not directly represent torque (although it does have a factor in its equation).
Get a class H insulation if possible (makes your motor last longer)
Get a motor around 150lbs (Wouldn't risk a motor that's too light, it won't have the oomph you need. a few extra pounds is A-o.k. but a significant amount of extra pounds limits your range)
Get one with a male shaft
A keyed shaft is easier to work with but you can still work with a spline shaft
Try and get the coupler that goes on to your motor when you buy it/rip it out (saves you $$ and time)
When looking for a different motor:
Ac is not the way to go for your first conversion (or do i just have low expectations of myself?)
You can tell if a motor is AC if it is a 1 phase or 3 phase motor
Pancake motors are usually not good candidates for car conversions. (Yeah you saw the one on ebay. They overheat easily)
Golfcart motors are seldom powerful enough for a conversion
Motors specifically made for EV conversions are the best but its gonna cost you.
You do have to look at many factor such as volts, amps (which gets you Hp). Torque is nice to know. Continuous Hp. So many factors!!!
"HP is HP Electric motors and gas engines are rated differently w/r/t HP. And they have different torque curves. But one HP from an electric motor shaft is exactly the same as one HP from a gas engine shaft at the same RPM "- Major
If there is any more helpful hints I'll be happy to add them
