DIY Electric Car Forums > EV Conversions and Builds > Controllers
Old 03-27-2011, 11:00 AM
Mad Professor Mad Professor is offline
Mad Professor is on a distinguished road
Question Please help identify this Electrofit Zapi Ltd High Frequency 48volt Controller
Good day all.
Can anyone here please help me identify this Electrofit Zapi Ltd High Frequency 48volt Controller?
From looking on google ect, it looks to be a version of the H2 Model, but I am not sure what version.
I can't find any part / model number stamped anywhere on the unit, the only stamped marking is "E6348" and I am guessing this in the units serial number.
And can anyone tell what the little black box in the top centre is?
Thanks for your time.
Best Regards.
Old 03-27-2011, 03:53 PM
piotrsko piotrsko is offline
piotrsko is on a distinguished road
Default Re: Please help identify this Electrofit Zapi Ltd High Frequency 48volt Controller
have you tried ringing up on the telly using what looks like the phone number under the union jack?
or google the number and see if it matches the case name
Old 03-27-2011, 04:12 PM
albano's Avatar
albano albano is offline
albano is on a distinguished road
Originally Posted by Mad Professor View Post
Good day all.
Best Regards.
Hello Mad,
This controller look the same as I have here in my shop it a sepex traction controller. Mine came out of Hyster reach truck.
Albano
Albano dos Santos
Old 03-28-2011, 12:31 AM
piotrsko: It is indeed a UK tel number, but being a weekend there was no answer, I will be trying to contact someone again today.
Old 03-28-2011, 02:23 AM
Just been on the phone to Electrofit Zapi Ltd, and spoke to a nice lady, that confirmed it is an old Zapi H2 model.
I then asked about the programming console, and serial cable + PC software.
Programming Console £236.34 + VAT.
Serial cable & Software £233.31 + VAT.
Old 03-28-2011, 05:44 PM
sounds like you need to contact hyster and see if they can do the programming for you. 400 pounds sounds a bit pricey for a one-shot
Old 04-02-2011, 02:04 AM
I have been able to find the Zapi PC Software, and after some reverse engineering, I was able to make a serial interface cable.
I am now able to change all the settings within the Zapi controller.
Also the controller logs hours of use, and if the reading is right this controller has only had 675h of running use.
Old 04-08-2011, 12:34 PM
Below is the exported data that I was able to pull from my Zapi H2 Controller.
[Info]
Chopper_Name=H2 REGENER. V2.1
[Code;Name;Position;Menu;Value;Scaled Value]
0;ACCELER. DELAY ;0;0;5;LEVEL = 5
12;INVERS. BRAKING ;1;0;3;LEVEL = 3
11;RELEASE BRAKING ;2;0;5;LEVEL = 5
13;PEDAL BRAKING ;3;0;5;LEVEL = 5
14;BRAKING MODUL. ;4;0;5;LEVEL = 5
15;CURVE BRAKING ;5;0;5;LEVEL = 5
58;CURVE TIME ;6;0;0;LEVEL = 0
56;AUXILIARY TIME ;7;0;5;LEVEL = 5
59;BACKING TIME ;8;0;5;LEVEL = 5
21;CUTBACK SPEED 1 ;9;0;9;LEVEL = 9
22;CUTBACK SPEED 2 ;10;0;9;LEVEL = 9
23;CUTBACK SPEED 3 ;11;0;9;LEVEL = 9
53;COMPENSATION ;12;0;5;LEVEL = 5
71;WEAK DROPOUT ;13;0;5;LEVEL = 5
63;MAXIMUM CURRENT ;14;0;9;LEVEL = 9
27;CREEP SPEED ;15;0;0;LEVEL = 0
30;MAX SPEED FORW ;16;0;9;LEVEL = 9
31;MAX SPEED BACK ;17;0;9;LEVEL = 9
112;BYPASS CONTACTOR;0;1;0;BYPASS
120;SPEED CONTROL ;1;1;1;ON
121;BATTERY CHECK ;2;1;0;OFF
122;ANTIROLLBACK ;3;1;1;ON
123;RELEASE BRAKING ;4;1;1;ON
125;HOUR COUNTER ;5;1;0;RUNNING
100;QUICK INVERSION ;6;1;0;OFF
101;SAFETY SWITCH ;7;1;0;SEAT
128;BACKING FUNCTION;8;1;0;OFF
127;SOFT BRAKING ;9;1;0;OFF
126;AUX FUNCTION ;10;1;0;CURRENT GAIN
84;MODEL TYPE ;0;2;0;REGENERATIVE TR.
145;SET BATTERY TYPE;0;3;3;48V
140;ADJUST BATTERY ;1;3;63;42.6 V
141;SET TEMPERATURE ;0;131;5;15 °C
142;SET CURRENT ;0;129;0;600 A
[End]
[Validation]
Code=FF4F
[Stop]
For anyone that is intrested here is a copy of the Zapi H2B Manual <Click Here.
Best Regards.
Old 09-30-2012, 11:30 AM
I have had a number of people sending me private message's asking for my details on this Zapi H2 unit.
One questions that I get asked often is: what is the max voltage / amps can this unit cope with.
I know Zapi have a range of voltage and current models.
So I have pulled my unit apart to have a look at things.
I can see it may be possible to change a few parts on the logic board so that it would be able to cope with higher voltages, but I am more interested to find out the voltage and current limit of the power board.
Here is a list of some of the parts on the logic board
----- Logic Board (ZP321C)-----
Q1 - IRF530N
Q2 - IRF530N
Q3 - IRF530N
Q4 - IRF530N
Q5 - IRF530N
U1 - TC4429EPA
U2 - MCT7805CT
U3 -
U4 - 74HC373N
U5 - XDP610P
U6 - TD62083AP
U7 - M74HC4538B1
U8 - LM2901N
U9 -
U10 -
U11 - LM2901N
U12 - LM2901N
U13 - MM74HC4049N / MC74HC40449N
U14 -
U15 - SN74HC04N
U16 - CNY 17-3
Here is a list of some of the parts on the power board.
----- Power Board (ZP338F) -----
Q1 - G2233HEX
Q2 - G2233HEX
Q3 - G2233HEX
Q4 - G2233HEX
Q5 - G2233HEX
Q6 - G2233HEX
Q7 - G2233HEX
Q8 - G2233HEX
Q9 - G2233HEX
Q10 - G2233HEX
Q11 - G2233HEX
Q12 - G2233HEX
Q13 - G2233HEX
Q14 - G2233HEX
Q15 - G2233HEX
Q16 - G2233HEX
Q17 - G2233HEX
Q18 - G2233HEX
Q19 - G2233HEX
Q20 - G2233HEX
Q21 - MPSA92
Q22 - N/A
D1 - U30D20C
D2 - U30D20C
D3 - U30D20C
D4 - U30D20C
D5 - U30D20C
D6 - U30D20C
D7 - U30D20C
D8 - U30D20C
D9 - U30D20C
D10 - U30D20C
D11 - 1N400?
D12 -
D13 -
D14 -
C1 - 1000uf 100wv
C2 - 1000uf 100wv
C3 - 1000uf 100wv
C4 - 1000uf 100wv
C5 - 1000uf 100wv
C6 - 1000uf 100wv
C7 - 1000uf 100wv
C8 - 1000uf 100wv
C9 - 1000uf 100wv
C10 - 1000uf 100wv
C11 - 1000uf 100wv
C12 - 1000uf 100wv
C13 - 1000uf 100wv
C14 - 1000uf 100wv
C15 - N/A
C16 - 4.7uf 100v
C17 - 22nJ100
C18 - E473K 6UZ
C19 -
C20 - 22nJ100
C21 - 22nJ100
C22 - 22nJ100
C23 - 22nJ100
C24 - 22nJ100
C25 - 22nJ100
U1 - LMT2904N
U2 -
R1 -
R2 -
R3 -
R4 -
R5 -
R6 -
R7 -
R8 -
R9 -
R10 -
R11 -
R12 -
R13 -
R14 -
R15 -
R16 -
R17 -
R18 -
R19 -
R20 -
R21 -
R22 -
R23 -
R24 -
R25 -
R26 -
R27 - 1.2K J 5W
R28 - 1.2K J 5W
R29 -
R30 -
R31 -
R32 -
R33 -
R34 -
R35 -
R36 -
I will update the list above, as I find out more details.
