Old 03-27-2012, 01:40 PM
somanywelps somanywelps is offline
somanywelps is on a distinguished road
Default Re: Starting new build: BMW 3-series (E46) - high-performance electric
Originally Posted by attaman View Post
lot of work is not a problem... how do you reverse engineer the ECU source code?
I don't think you can get away with only "cam and or crank" signals, there are a bunch of sensors/wires going from the ICE into ECU. Wrong signal on any of them should trigger an error (otherwise it's useless and wouldn't be there). And all those signals depend on each other in some non trivial ways and define the working engine regime... all kind of pressures, temperatures, RPMs etc...
You either need to mimic all of them, or completely rewrite the code which will not care about them... mimicing with the black box sounds more realistic...
In our E46 dashboard only the speedometer and odometer work, everything else is in a "christmas tree" mode, all possible lights are on.
ABS - not sure, probably it's a completely standalone system, but haven't tested yet )
What? I know the tach has a mech mode so that's easy; I thought valerun said you had warning light suppression.
Try posting in that diagnostic subforum I linked.
You can also try the engine swaps because they're tooling around with the instrumentation too for their LSx engines.
Old 03-29-2012, 09:30 PM
What is with the swimming effect on the longer video?
Also how many 100Ah cells are in that top battery box? (22?)
Old 03-30-2012, 04:37 AM
Thaniel's Avatar
Thaniel Thaniel is offline
Thaniel is on a distinguished road
Some of the information I have is from this post that had an ICE swap (man after my own heart)
http://forums.bimmerforums.com/forum...9&postcount=29
and
http://forums.bimmerforums.com/forum...6&postcount=32
Also comunicated with another EV'er that did an e46. In the E46 EV he just removed the ECU and claimed that the HVAC and other things still worked and were controlled out of the instrument cluster (he never did get the tach to work though). But that goes against what the E46 LS1 project said which claimed many systems didn't work without the ECU. SO i've read many conflicting messages. Could be some variation from year to year?
It may be that I won't know until I do my own swap. Plan to turn my E36 EV into and E46 EV when I get back to the USA this fall (currently in Sweden). But any info I can gather beforehand is good stuff.
Converting a 3 series BMW to EV. Thread:
http://www.diyelectriccar.com/forums/showthread.php/and-so-begins-17727.html
Blog (has more part#'s): www.ev-36.blogspot.com
Previous Engine swap experience:
2002 LS1 V-8 (think corvette) and 6 spd manual into a '93 3-series BMW (daily driver) http://www.ls1bmw.blogspot.com/
2000 Nissan Maxima V-6 and 350z 6 spd manual into a '91 Rx-7 (sold) http://www.v6rx7.blogspot.com/
Old 05-24-2012, 01:15 AM
valerun valerun is offline
valerun is on a distinguished road
busy busy busy times.
Second prototype completed with accessories.
First test drives at Google's Earth Day event last month
Huge Maker Faire event this past weekend - 2,000-4,000 people stopped by.
We made Engadget: http://www.engadget.com/2012/05/22/e...r-faire-video/
Gearing up to public conversions / kit sales this quarter.
Valery
Electric Fiat Spider, BMW 3-series (x2): http://tinyurl.com/7x7oaa2; BMW X5: http://tinyurl.com/7yu23op
DIY 10kW Charger: http://tinyurl.com/73oz2oe and http://www.emotorwerks.com/tech/electronics
Android EV Dashboard: http://tinyurl.com/8xucxxa
Old 05-24-2012, 11:33 AM
1-ev.com's Avatar
1-ev.com 1-ev.com is offline
1-ev.com is on a distinguished road
Valery
Val,
Great Job!!! please check your email...
-Y.
"Y" <- this is my favorite question...
+ '68 911 -100% Electric with "Race" and "Eco" modes: http://1-ev.com and http://www.evalbum.com/3978
+ Helping your business to get more business: http://efixpc.com
Old 06-23-2012, 09:16 PM
drgrieve drgrieve is offline
drgrieve is on a distinguished road
Hi Valery - been meaning to ask this question for awhile now. In the video you causally mention regen in the upcoming controller. Is this DC (interpole?) or AC?
Any titbits welcome ....
Old 06-24-2012, 12:59 AM
DC SepEx. Similar power to Series.
Old 06-24-2012, 09:30 PM
tomofreno tomofreno is offline
tomofreno is on a distinguished road
Valery
Noticed some cells laying on their sides in the trunk. According to the link below they are not supposed to be mounted that way. Not so?
http://visforvoltage.org/forum/9972-...ll-orientation
Also, what "next generation" batteries were you referring to?
You interview well.
Old 06-25-2012, 03:08 AM
TomA TomA is offline
TomA is on a distinguished road
You interview well.
Jack Rickard has been running a 20 or so cells laying flat in his second build of the red Porsche speedster for well over a year with no apparent problems. Just a data point. It would sure be easier for packaging if this turned out to be a non-issue. BTW, nothing in the mfr literature warns against this orientation...
Old 07-10-2012, 09:04 PM
Hey that's an interesting development!
Are you building a DC SepEx controller? Able to share your target parameters - volts, amps , regen amps etc
I've seen a few SepEx motors around - Kostov sell some - which are you planning to use?
Are you going Calb "grey" or Sinopoly "black" for your future builds?
Thanks,
David.
