Originally Posted by mora
.. So if that component is missing circuit isn't complete.
Good. So we know it is in series with the negative input lead.
There was no writing on the other side but PCB had silkscreen printing "L2".
Ah. I'd say it's 99% sure that this component is an inductor.
Should I try bridging that component with some wire?
You could do that, but I'd run it from a current limited source like a power supply that you can set the current limit on. I'd start with perhaps a 1 amp limit, even though it might not pull in at that current. There is a good chance that whatever caused L2 to overheat will still be causing way too much current to flow. If the power supply limits itself to a low voltage with 1A flowing continuously, you can say with reasonable certainty that there is still a fault there.
[ Edit: one amp at 12 V is still plenty of power to let smoke out of components. So be very watchful still; don't imagine that the 1 A limit will prevent all possible adverse events, like components burning up. ]
If it all works, [ edit 2: and you don't get a better clue about the value of L2, e.g. by measuring the inductance from a good economizer ] you could do worse than replacing L2 with a surface mount inductor that is capable of handling 3.8 A peak. It looks like a 1515 (4mm x 4mm) component to me, but it's hard to tell from the photo. Any inductance in the range 5 to 50 microhenries would be appropriate, I'd guess. Perhaps less, perhaps down to one microhenry, because of the rather large currents involved.
It will probably work fine with L2 shorted permanently; it's just that a little more of a spike may find its way back into the 12 V circuits that way. But consider that L2 acted as a kind of fuse last time; replacing it with another inductor may prevent worse burning up of components if this sort of thing happens again. It doesn't have to be an accident with a cable; voltage spikes in cars are a fact of life. The inductor will also help protect the economizer circuit from moderate spikes on the 12 V line from elsewhere. (The accidental cable connecting would be considered a jumbo spike
