The top ten EV Conversion battery chargers for 2011 according to
EVAlbum are...
- Zivan
- Manzanita Micro
- Elcon
- Quick Charge
- Russco
- Brusa
- Delta-Q
- Kelly
- Lester
- Soneil
- Prices run from $400 to $4500
- Voltage output from 12 volts to 500 volts
- Watts from 1000 watts to 5000 watts.
- Some chargers use constant current, constant voltage and others use algorithms that are programmable. Some have dials that can the user can control the maximum voltage or maximum amperage. Some give the user a few choices of charging curves. Some are programed to perimeters before shipping.
- Other factors to consider are; display panels with warning LEDs, digital displays, protection from output over-voltage, over-temperature, reverse battery, short-circuit, vibration & shock resistant, sealed construction, method of cooling the charger, wide input voltage range, PFC (power factor correction) and or (power factor compensation) minimizes utility surcharges and maximizes use of AC power current, efficiency and track record.
See chart Here for some comparisons.
(this chart needs to be updated or posted here so it can be modified, as it doesn't accurately reflect all of the chargers from manufacterers like Zivan and DeltaQ, which many people use)
