DIY Electric Car Forums > EV Conversions and Builds > EV Performance
Old 02-08-2012, 08:27 PM
John Metric's Avatar
John Metric John Metric is offline
John Metric is on a distinguished road
Default DC Plasma - Build Thread - 10Sec Fiero
Nine (9) Second Fiero now
Well, I thought I would start a thread on my build as it is rather unique car. (and someday someone else may try to do the same crazy thing)
I documented the entire thing with pictures, that are all over in various locations, I will try to link them all in here if anyone has a specific request for a particular shot. This is the best video link
http://www.youtube.com/watch?v=5LR-BZcIuC0&feature=share&list=PLA3E4F9ED20798E34
I was originally going to build a Diablo kit and bought an Oklahoma car that had sat dead in Austin for a long time (17 years?) 88,000 miles Red 2M4 for $1000 on ebay. I finished thrashing the leaky 4 cylinder for about 30 minutes until the heads blew all the way through and the bulk of the radiator fluid got in the oil system. Right after that I spent 8 months in Alberta and watched them racing electric snowmobiles and became convinced that the off the line torque of an electric motor was tremendous. I then saw some electric car drag racing in Vancouver/Portland area and I was hooked. Very easily you can have sub 4 second 0-60 mph times and like my car we do 0-60 in 2.4 seconds with the drag radials.
I decided to build to the National Electric Drag Racing Association classification called MC which is Pro-Modified Street Conversion.
I also occasionally race in SCCA slalom racing courses but they haven't found a category for me yet.
From the beginning we targeted putting the batteries in the trunk do to the nice "water tight" nature of the compartment.
Our target was to beat the White Zombie at 10.25 seconds.
Here is one of the more recent shots someone took at the Texas Mile in Beeville TX.
you can see a video of the build here...
http://www.youtube.com/user...98E34/10/Hh_9irEYFJ8
Some of the main modifications:
Replacement of the engine cradle with a Lincoln Mark VIII rear end and suspension.
Removal of the gas tank and substitution of a slightly wider (1" each side) torque tunnel into which we inserted two Netgain Warp9 motors, each capable of sucking 400 battery HP. Fiero was amazing this way in that the large what looks like a transmission tunnel down the middle is the gas tank area (A lot of people are surprised to learn that) worked out perfectly for the motors. Everything is to the rear of the original front "firewall" so we can maintain "mid-engine" status.
Nearly direct coupled, (really a short coupled DANA Spicer 1350 driveshaft) the motors to the differential. Installation of a 1200HP Gear Vendors overdrive so we have two gears (really 1.5).
Installed a five point roll cage.
Firestone Air bag rear suspension
12" Corvette brakes in front by West Coast Fieros thanks Chris West
Two motor controllers, good to supply 425 battery HP to each motor by Cafe Electric
Controller cooling system
LiPo battery pack by Lithium Start 2400A 375V (peak ratings) 6P90S
LiPo Battery Management System by Elithion
KYB shocks all around
Sport Edition CD 16X7.5 wheels 5X100 on the front, 5X108 on the rear
BFG Drag Radials 255/50R16
Eagle GT's 225/60R16 for running around town and the slalom courses
Catchin some rear wheel air...on the slalom course in the Macy's mall parking lot in Hagerstown MD
Catchin some front wheel air at Houston Motorsports Park in Houston
More front wheel air at Royal Purple Raceway in Baytown Texas.
One of my favorite shots index racing in the 7.0 1/8th mile Brandt Nationals at Lonestar Motorsports Park in Sealy TX
Best times so far...
60ft 1.551
1/8 mile 6.321 112mph
1/4 mile 9.898 134mph
1/2 Mile 134.5mph
1.0 mile 155.0mph
Old 02-08-2012, 08:47 PM
LithiumaniacsEVRacing's Avatar
LithiumaniacsEVRacing LithiumaniacsEVRacing is offline
LithiumaniacsEVRacing can only hope to improve
Thumbs up Re: DC Plasma - Build Thread - 10Sec Fiero
Looks good John!
Can't wait to see ya on the track, coming this way in 2012?
You know all NEDRA members are welcome at ECEDRS events. It would be nice to get us all together in 2012.
Ronald Adamowicz
President of The NEMRS
www.NEMRS.net
Enzo Ferrari "Horsepower sells cars, torque wins races".
Old 02-08-2012, 08:54 PM
Default Re: DC Plasma - Build Thread - 10Sec Fiero
View of my battery pack. Its 155lbs 333V nominal LiPo made from off the shelf parts. Standard off the shelf LiPo packs, Elithion BMS and BRUSA charger talking via CANBUS. 6P90S Polyquest/Enerland by A123 Korea.
4400mAhr cells 45C/90C 30 second burst rating. Factory matched.
What I see for gauges., Twin Zillaview session on my netbook. Also, logs data to text file for each trip.
PVI Diagram for DC Plasma for the single Zilla arrangement. Each line represents one of the system components operating windows. You can match components by comparing the windows.
Simulated Dyno charts for inputs to motor. These are calculated from zilla outputs not rear wheel figures. Motor efficiency and driveline losses would need to be added for rear wheel figures. But this is real data for starting off purposes. It has worked well in my drag modeling software that steps by 0.01seconds through a run.
Comparison of one zilla across two motors in series versus two zillas one to each motor.
My little pack put out 830battery horsepower peak on this run from June.
Old 02-08-2012, 08:57 PM
I needed the 1.21 Gigawatts of a lightning bolt to create the 800 battery HP to get down the 1/4 mile in 11.5 seconds. Taken from my truck window during intense thunderstorm over South Bend IN on my way to Power of DC 2011.
Old 02-08-2012, 09:06 PM
I was wondering why I had no power left when my pack was still 10 to 20V above nominal. I had previously thought nominal might be somwhere near the middle SOC. But it turns out that 3.7V LiPo chemistry 3.7 is nearly empty.
I created this chart for recharging at the track. I never charge above 4.15V or discharge below resting voltage of 340V
This is a summary of some settings DC Plasma racing has tried over the 2011 Racing Season. You can see the early trials at 1200A and 1500A. Then some runs at 1800 and 2000A with the total motor voltage limits when the motors were in series with one zilla. Then we switched to two zillas(x2) and kept the motors at 170V the entire run. Then we tried Overdrive(OD) and then finally 1800A, 190V and OD(battery hitting LBV gave the ratty line). Next trial will be 2000A and 190V and Overdrive.
Old 02-09-2012, 07:19 AM
DIYguy's Avatar
DIYguy DIYguy is offline
DIYguy will become famous soon enoughDIYguy will become famous soon enough
Send a message via Yahoo to DIYguy
Hey John,
Nice job on the documentation. I'm almost thinking that this should be in the build thread section of the forum. . . certainly no one can argue with the performance connection.
So, I guess you finally found a sponsor then. . based on the team name etc.?
Cheers,
Gary
Old 02-10-2012, 03:13 AM
DavidDymaxion DavidDymaxion is offline
DavidDymaxion is on a distinguished road
Thanks for posting graphs.
Old 02-10-2012, 12:27 PM
Bowser330 Bowser330 is offline
Bowser330 is on a distinguished road
+1 the graphs are awesome! thank you for sharing those, it really helps those of us that are still learning.
Old 02-10-2012, 12:41 PM
Why is there such a drop in Torque (and thus the HP) after ~3000rpm
Was the amperage pulled back for some reason?
Is it due to the continuous rating of the Zilla? I would have thought the amperage would slowly taper down to the 600 continuous, not just drastically drop like that...if that is indeed the cause...
I was hoping to see the Warp9 peak horsepower to be in the 4000rpm range...we need more peoples dyno's!!! I hope you have started a trend!
Old 02-10-2012, 05:30 PM
nedrapr nedrapr is offline
nedrapr is on a distinguished road
Great going John, getting this up on DIY.
