Originally Posted by jddcircuit
My hardware is not ready for prime-time. However it is looking promising and unique to other solutions in a couple ways. I am not prepared to post the full schematic and layout yet. Possibly soon.
I am looking forward to doing the software but I will be reaching out for assistance when I hit a wall.
OK, let me know. I just wouldn't want a slick hardware design to be buried for months because you get lost in the Android world. I created the BlueTooth stack for Arduino (it's a port of
BTStack), so let me know if you want to go that way - it may give me some incentive to work on an upgrade that I haven't, yet, made time for.
Android is actually a pretty easy platform to program.
As I say, I'd be happy to build up the circuit and test it so that you have at least one other installation before you send it out to the world. On the other hand, there may be better candidates watching this list since my expertise is definitely on the software side rather than hardware debugging.
My cell monitoring method is only a piece of my project. It will be integrated with my own battery charger and motor controller that interfaces with a junkyard Prius inverter.
Yep, a little local intelligence opens up a whole world of possibilities.
One of the problems with conversions is that they need TLC. For the most part, you couldn't give your grandmother your conversion and have her just drive it.
The system you're building brings us closer to a system that automates what can be automated and will provide a notification so that your grandmother can call and tell you what the system says needs attention.
I have several balancing ideas. Plan A is to not have any on board but know when it is time to balance using the cell voltage monitoring.
With the voltage monitoring I should know which cells are at a higher state of charge than the rest because they reach the high voltage cutoff first each time during charging.
Surely, and for the bottom balancers the same hardware applies, it's just a minor software change to balance before charging rather than after (if I understand bottom balancing correctly).
A simple circuit to remove a specified amount of amp hours from those high cells should be enough to improve the balance. I plan to use the same wiring harness that my monitoring circuit uses to tap the cells for this periodic balance.
I wonder about mixing "high" power, I suspect to balance you'd be looking at 10W+, in with the low power monitoring circuit.
I would expect to use, say 1A, fuses for the monitoring circuit - connected directly to the terminals or the straps of the cells. Inline glass fuses seem to be the lowest cost if you're not anticipating replacing them. I think that you can embed them in a battery lug in the style of the zeners in the
Lee Hart Balancer.
My other problem with dissipative is that, well, it's dissipative. You go to the trouble of charging the cells and then start discharging them. I know it's infrequent and the charge loss is minimal, but it still bothers me.
