Old 04-20-2012, 11:23 AM
Yukon_Shane Yukon_Shane is offline
Yukon_Shane is on a distinguished road
Default Evnetics Developing a DC/DC Converter
I thought this deserved it's on thread...
Originally Posted by Tesseract View Post
I finally caved on this and am designing a DC/DC converter. To keep costs down it is not going to have any programmable frills - not even adjustable output voltage - but it will be water-resistant, if not water-proof, accommodate a very wide input voltage range (probably 90-425V), be naturally capable of paralleling, short-circuit protected, reverse-input voltage protected (no way to protect against connecting pack voltage to the 14V output, though) and somewhere around 40-50A max output current - depends more on the thermal stuff than anything else.
Should have a prototype done in a month or so. Estimated cost of the production unit will be pricey - probably in the $400 range because, sorry, we make kick-ass stuff in tiny quantities and don't use slave labor, so... definitely a "get what you pay for" kind of thing.
I don't know about the rest of you but I'm pretty excited to have a purposed built EV DC/DC convert that's available to the DIY community. My IOTA is probably the weakest component in my current conversion and I'll be happy to replace it with something that's design to handle up to 425 VDC.
Shane
Old 06-26-2012, 01:08 PM
Default Re: Evnetics Developing a DC/DC Converter
Any updates on the progress of this project from the Evnetics guys?
I got $400 burning a hole in my pocket
Old 06-26-2012, 01:44 PM
Tesseract's Avatar
Tesseract Tesseract is offline
Tesseract will become famous soon enoughTesseract will become famous soon enough
Not much since that post, I'm afraid. I've designed most of it in my head, along with a few calculations here and there to nail down some of the particulars, but it might be another month or so until I make a prototype.
Chief Electron Herder for Evnetics, LLC.
Into EV's? Check out ChargedEVs Magazine
Old 06-26-2012, 05:13 PM
etischer etischer is offline
etischer will become famous soon enough
IOTA is the weak link in my conversion too, I've already had one fail. The voltage boost input (boosts output voltage from 13.8 to 14.3) has stopped working on my second one. The voltage boost is a great feature, saves the 12v battery from boiling when the ignition is off, and keeps the headlights bright when the ignition is on.
It would be great to have a fanless DC-DC, is it possible? IOTA is not designed to take the heat of being trapped in a hot car in the summer, the fan is always going 100%.
Old 06-26-2012, 08:47 PM
ruckus ruckus is offline
ruckus has a little shameless behaviour in the past
Get a Chinnoz, Chennic, elcon, or whatever it is they call them this week. Use 4 headways as a 12v stabilizer. You will have no problems.
Of course, once it comes out, a 'made in U.S.A.' dc-dc would be a nice premium option.
p.s. can you up the voltage to about 800?
www.northvalleyev.com
Old 06-26-2012, 09:23 PM
TheSGC TheSGC is offline
TheSGC is on a distinguished road
After a few dead DC/DCs I ended up getting a Zivan DC/DC for $550, so in the $400 range is a bargain in my books.
2001 Civic EX EV
http://2001-civic-ev.blogspot.com
EV's are never done, they just reach a point where you can drive them.
Old 06-26-2012, 11:51 PM
onegreenev's Avatar
onegreenev onegreenev is offline
onegreenev is on a distinguished road
Using a MegaPack for my DC DC. Works great. UP to 300 plus volts. Not usable below like 120 volts. Best if you are at least that or above. Fan runs all the time but I am setting up a thermal fan switch.
Change comes, one conversion at a time.
http://onegreenev.blogspot.com/
Old 06-27-2012, 04:24 AM
I'm running 340v currently, and need 60A output. It doesn't look like Chennic/elcon has anything, I'd have to run two in parallel.
Old 06-27-2012, 04:31 AM
skooler's Avatar
skooler skooler is offline
skooler is on a distinguished road
Jeffrey,
Put me down for one as soon as its ready!
Are you taking deposits!? (seriously!)
Cheers,
Mike
Old 06-27-2012, 05:48 AM
adeyo adeyo is offline
adeyo is an unknown quantity at this point
Default
Sorry, newb question, but what exactly does a dc/dc converter do? ...& where does it fit in the EV system?
