I have frequently thrown the gears in the opposite
directoin of movement and taken off without trouble,
both with my Prius (PM AC motors) and the EV Electricar
(Hughes AC induction motor).
I never managed to keep the field stalled...
[top]
Regards,
Cor van de Water
Chief Scientist
Email: xxx@xxx.xxx Private: http://www.cvandewater.com
Skype: cor_van_de_water XoIP: +31877841130
Tel: +1 408 383 7626 Tel: +91 (040)23117400 x203
-----Original Message-----
From: xxx@xxx.xxx.edu [mailto:xxx@xxx.xxx.edu] On Behal=
f Of Morgan LaMoore
Sent: Wednesday, April 25, 2012 10:00 PM
Subject: Re: [EVDL] How To Burn Up Your DC Motor
It's closer to "makes a bit of heat", and the controller software should ma=
ke sure that the amount of heat is acceptable.
Lee's comment on not motoring forward while going in reverse was about AC i=
nduction motors, not synchronous (PM) motors.
With an AC drive, the peak current through a phase (transistor and
winding) is 1.4 times higher than the RMS current. So if you have a synchro=
nous motor stalled so that one phase is at peak current, that phase will se=
e twice as much power dissipation as usual, which could overheat it.
The same thing can happen with an AC induction motor if it is moving backwa=
rds at exactly the slip speed; in that case, one phase sees DC and could se=
e a DC current of 1.4 times the RMS design value.
If the inverter software limits the current in such situations to less than=
70% of the normal continuous current limit, then that should limit the cur=
rent to the normal ratings and avoid overheating everything. I would hope t=
hat the car companies thought about these situations and protected against =
them in software.
With a 3-phase drive, stalling puts 1.4 times normal current though a phase=
, leading to twice normal resistive power dissipation. With a commutator, a=
ssuming the brushes cover 1/4-1/3 of the commutator bars at any given time,=
stalling leads to 1.73-2 times the normal current through the comm bars as=
well as vastly reduced cooling, leading to
3-4 times the power dissipation with nowhere to get rid of the heat and les=
s mass to absorb the heat.
So stalling is much harder on a commutator than it is on a 3-phase AC motor.
-Morgan LaMoore
[quote] Jay Donnaway <xxx@xxx.xxx> wrote:
> The parallel parking discussion raises another difference between the Lea=
f and an i-MiEV. The i allows some preload of the motor while still on t=
he brake, such as when starting motion while pointed uphill. Also,when '=
idling' in drive at 1-2 mph, a definite 'cogging' can be felt.
> Lee raised in this thread that it's bad for a synchronous motor to be pow=
ered forward while rotating in reverse, IIRC. A real common occurranc=
e could be when shifting from Reverse to Drive in a fixed gear, synchronous=
AC-motored EV like the i, such as when backing out of the driveway or star=
ting on a hill. On the scale of Makes a bit of Heat to Really Bad for th=
e Motor, how bad would the practice of shifting to Drive while rolling in R=
everse be? There is no lockout to prevent this action on the i.
| Moratorium on drag racing discussion is in effect.
| Please take those discussions elsewhere. Thanks.
| REPLYING: address your message to xxx@xxx.xxx.edu only.
| CONFIGURE: http://lists.sjsu.edu/mailman/listinfo/ev
