Old 05-07-2012, 10:34 PM
CrunchTime CrunchTime is offline
CrunchTime is on a distinguished road
Default Re: Zivan NG3 Wiring
On my Zivan, the grey 50A Anderson output connector has + and - marked on it?
1995 BMW E36 328i
Old 05-07-2012, 11:11 PM
Tedktis Tedktis is offline
Tedktis is an unknown quantity at this point
Mine as well, but the Zivan Tech told me specifically to check the polarity regardless. Idk know why, except when I wired the input end (blue and brown) he said it didn't matter as long as I checked the polarity on the output. It's an AC current from the wall outlet so does it really matter on the connection position of the input wires? I was also told that the smaller top prong is hot and the larger prong is neutral. The green/yellow can only go the lower earth prong.
Old 05-11-2012, 08:45 AM
What gauge wire is recommended for charger-to-batteries?
Old 05-13-2012, 09:03 PM
racunniff racunniff is offline
racunniff is on a distinguished road
It depends on the voltage of your main pack - since the Zivan puts out different amps at each voltage level (see http://www.zivanusa.com/NG3BatteryCharger.htm for details). Once you know how many amps are going out, you can size your wires. My favorite chart is at http://www.powerstream.com/Wire_Size.htm
For most conversions in the 100 volt-ish range, 8 or 10 gauge wire should be sufficient. But your mileage (and current) may vary...
Old 05-14-2012, 05:32 AM
Thank you, great links. looks like #8AWG for me. Now how to Wire em up?
