DIY Electric Car Forums > EV Conversions and Builds > Electric Motors
Old 05-27-2012, 08:03 PM
efan efan is offline
efan is on a distinguished road
Default Re: Conversion BMW Z3 which motor fits best?
this controller+motor seem to be a new development, and I dont know of anyone who has used it..but it may be worth checking them out.
http://shop.greenstage.co.nz/product...-motor-package
Old 05-27-2012, 08:18 PM
njloof njloof is offline
njloof is on a distinguished road
Default
Originally Posted by Elegancec View Post
Question about Solution 1 controller:
The website states 9-340V DC output.
The Kostov 11 Alpha wants 240V. So in my opinion the controller makes a pwm signal of it. So the battery system has to provide 250V, is this correct? So its not possible to use an 100V battery pack as an example?
You can certainly drive the Kostov with 100V, but your max RPM will be severely limited. Even if your battery system is rated at 250V, it will sag below 240V under load. Better to target 300V, the controller's pwm will limit to 240V if you instruct it to never exceed this voltage.
Old 05-27-2012, 08:33 PM
somanywelps somanywelps is offline
somanywelps is on a distinguished road
The K11A is rated 250V. You're going to want to be sitting with a nominal of above 300V depending on the total kwh of the pack and the peak amperage draw.
No, 100V would be bad.
Old 05-27-2012, 08:45 PM
Default
Wow -- that deserves its own thread!
Old 05-29-2012, 04:46 AM
albo2 albo2 is offline
albo2 is on a distinguished road
There is also this
http://www.ev-power.com.au/-95-EV-Mo...nduction-.html
Old 05-29-2012, 06:45 AM
Elegancec Elegancec is offline
Elegancec is on a distinguished road
Hello, this motor is too small, only 120Nm at 3000rpm this is 100km/h or 65mph.
Old 05-29-2012, 07:46 AM
marc02228 marc02228 is offline
marc02228 is on a distinguished road
Hi Elegancec,
where are you from? I thought about the K11" alpha and soliton 1 in a Z3, too. But decided to put that stuff in a Miata due to the weight.
Old 05-29-2012, 02:51 PM
Hello Marc, Im from Germany, near Kiel.
At the moment I can not see another solution as the kostov motor as useful.
On next monday I have a date with our transport of ministry to make a check list.
The BLDC Motor from Scott has negative effects like noise and vibration and low efficiency at low speeds - I do not have a diagram or values for this until now. Also there is no EMV / EMC document available up to now. This could be a problem with the transport of ministry.
The kostov engine can be bought in the EU, so I would save the taxes for import.
Old 05-30-2012, 08:45 PM
ruckus ruckus is offline
ruckus has a little shameless behaviour in the past
Actually, for the $$$ you will spend on a failure-prone brushed dc motor you should consider a system without the Achilles heel. About the same price for a lot more performance.
www.northvalleyev.com
Old 05-31-2012, 12:59 PM
The BLDCs don't have the performance and certainly don't have the price performance.
Also he linked to a BLDC, but there was some discussion about that motor/controller and not in a positive light.
