DIY Electric Car Forums > EV Conversions and Builds > Electric Motors
Old 05-23-2012, 09:35 PM
NintendoKD NintendoKD is offline
NintendoKD has a little shameless behaviour in the past
Send a message via AIM to NintendoKD Send a message via Skype™ to NintendoKD
Default informative video on motors and how they work
I found this video on you tube, it is old, but still valid, and very informative.
http://youtu.be/g28o0Ih3Cc8"> http://youtu.be/g28o0Ih3Cc8" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355">
http://youtu.be/_c6KgpxTWos"> http://youtu.be/_c6KgpxTWos" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355">
enjoy
I am just going to post the URL here:
http://www.youtube.com/watch?v=_c6KgpxTWos
http://www.youtube.com/watch?v=g28o0...feature=relmfu
A lot of money first. A good light weight vehicle. 9" motor, Soliton1, Synkromotive controller, Warp Drive Controller, Zilla Controller. A large pack of lithium batteries. 45 kWH at least. A good charger and lots of money. Oh, and more money. It will be expensive. You won't be able to do that with Lead Acid batteries. PETE
Most of the other stuff is minor compared to the car, motor, controller and battery pack.
Old 05-23-2012, 09:44 PM
Default Re: informative video on motors and how they work
Ok, so I tried two methods to get the two youtube videos to work here. I had no luck. The first method was to copy the URL from the address bar, and the second was to copy it from the "share" area. What did I do wrong?
Old 05-23-2012, 10:55 PM
onegreenev's Avatar
onegreenev onegreenev is offline
onegreenev is on a distinguished road
You just didn't figure it out. No biggie.
Pete
Change comes, one conversion at a time.
http://onegreenev.blogspot.com/
Old 05-23-2012, 10:59 PM
thanks green pete. the information underneath the video is also rich.
http://scitech.quickfound.net/
a search engine that was listed underneath the vid, amongst other things.
Old 05-23-2012, 11:01 PM
Pete
I now see how you did that, however, I do not understand where the "phrase" between the brackets came from. I WILL figure this out. I feel like an idiot, all of the forums I moonlight on and I can't figure this out?
Old 05-23-2012, 11:04 PM
onegreenev's Avatar
As an example of how to load a youtube directly into the thread you need to go to the advanced section rather than the quick reply. Here you will see a selection icon that says you/tube in white/black/red at the far right menu. You go to your youtube video you want to insert and only copy that portion that I have marked in RED.
youtube.com/watch?v=g28o0Ih3Cc8&feature=relmfu
You can see that some have more information behind the selected area but the selected area is what you need for youtube to be inserted directly using the available menu.
Just select the youtube menu and then past in the area in RED. Be sure you get all the information between the = and & But do not include them. Be sure you get it all. No spaces. But if it has a _ or - they are included. As you can see in the example. Go to youtube and find an EV related tube and post it for practice.
[ YOUTUBE ]g28o0Ih3Cc8[ /YOUTUBE ]
Old 05-23-2012, 11:33 PM
onegreenev's Avatar
The youtube stuff you see in brackets is not normally seen. It is just to show you an example of what YOU see when you select the youtube menu and where you are to paste in the video code. I made it show up by putting spaces in the brackets so it would not work. Just did it for a visual.
Old 05-23-2012, 11:34 PM
onegreenev's Avatar
Many forums don't allow youtube to be imbedded. Thankfully this one does. I like it.
Old 05-23-2012, 11:35 PM
onegreenev's Avatar
Oh yeah! Fun videos. Old but fun. Got more?
Old 05-23-2012, 11:37 PM
onegreenev's Avatar
Found one.
